ND Grad kits - what to go for
My anecdotal evidence points to the fact that most folk who buy a set of grads end up using them once or twice before relegating them to the back of the cupboard as they're unwieldy and tricky to use effectively without a bit of practice.
For that reason I'd say start off with a cheap set, see how you get on with them (magenta casts can be removed in PP anyway so they're not the end of the world) and if you like them save up for a set of Lees. If not (which statistically is more likely) then you won't have lost too much money and you can always sell them on to somebody else to have a play with.
I have heard that Cokin’s have a strong magenta cast if stacked.
If cameras went down to ISO1 we wouldn't need them
On a serious note I dunno why cams can't provide ISOs a lot lower then 80. At least they could go down to 25 or 12. A matter of reducing the gain post sensor, pre converters
Now if we had a very wide Dynamic range...
I've found as Hefty mentions that, rather suprisingly, I don't use them very often - despite the frequent comments in Photo Mags that they're essential for landscape photography I find that if you catch the best lighting there's usually no need, probably even less so with the K5 and it's additional Dynamic range/low noise which should allow more detail to be lifted from shadows without problem noise - can't wait to try it in practice when I get chance!!
Find me on Google+ link
Not sure How wide they go but I had some sucsess with them and as Simon Says, they give much less colour cast than Cokin. I had the wide 85mm holder kit and it did seem very well made and I didn't notice vignetting on my Nikon 12-24mm with it but then you can set some Automatic corner illumination/vignetting correction with the Nikons and Canons. (Was Not even mentioned in the Nikon Manual for my D90 but it was in the D700!)How it fares on the Pentax/Samsung variety I don't know...
I replaced the Cokin filters with Hi-Tech/Formatt and they are a lot better, though still have a slight colour cast. One of them has a dent in the filter surface (though I've never seen it show up in an image) and one has more of a hard edge rather than graduation where the filtration starts, so I'm not convinced their quality control is terribly good but they do the job for me.
Unlike others, I use the grads a lot: pretty much every dawn and dusk landscape shot I take is with a grad.
In terms of what to go for, I use the ND4 and ND8 grads. I have an ND2 grad as it came in the filter kit, but never use it.
I took a set of photos a few months ago at Whitley Court, one or two of which I stacked, but I could not be certain from the resulting images which were stacked and which were single filters. This image is (I believe) a stacked shot....
Totnes
In a side track from the time consuming nature of my current methods of exposure fusions and HDR – I am planning to invest in a set of ND Grads (ideally a soft and hard set of each). I have been reading a bit about Kood, Cokin, SRB Griturn (also made by Formatt like the Hitech) and Hitech. Lee Filters are just a pipe dream in terms of cost at the moment.
I have read some reviews of all these in Advanced Photographer’s latest issue and still can’t make my mind up about the pros and cons of each system.
I guess the Kood’s appeal in theory if they are any good – but I don’t want to chuck my money away if I might regret that decision.
As an early 40th birthday present I have been very lucky that my family have given a workshop day with the awesomely talented Joe Cornish in July – so I think it would be expected that I went along with some ND Grads anyway! I assume he would think HDR is a swear word
Cheers,
Morpheus71
