National PE 3057 & Wireless Triggers
selectcase
Posted 09/11/2008 - 22:05 Link
Hi All
After the very helpful advice I was given on a previous thread I bought some cheap radio triggers from e-bay which work well for £14 incl postage!!
My only problem is that I have a National PE 3057 flashgun which has a single centre pin and has a good number of manual settings, plus it has a safe trigger voltage - it works fine on the camera but will not work with the triggers. This is a shame as its a lovely flashgun with some good features - I wonder if the wireless triggers dont have enough power to trigger this gun? My other flashgun is a Pentax AF260SA - this works 100% with the triggers but I have no instructions for it and it appears to have no manual settings.
Can anyone recommend a good pentax or other flashgun with some manual settings that i can "play with" off the camera with the wireless triggers - my main aim is to learn about the various effects of flash at differant angles, powers etc without spending a fourtune.
many thanks
will
K7D DA 18-55 mk11WR|50-200 wr|DA16-45|Tamron SP90|lots of manual pentax glass
Mannesty
Posted 09/11/2008 - 22:09 Link
The AF500FTZ , a very powerful and versatile flash can be had quite cheaply, and has variable output. A manual for your AF260SA can be found here.
The AF500FTZ is a TTL, auto, or manual flash but TTL is supported only on *istD and *istDS bodies. It's manual or auto only on later DSLR bodies.
Another AF500FTZ here.
Edited by Mannesty: 09/11/2008 - 22:22
mikew
Posted 09/11/2008 - 22:18 Link
Can I ask who you bought the triggers from please.
selectcase
Posted 09/11/2008 - 22:43 Link
I bought the triggers from a uk seller on ebay i will try a find a link for you
ta for the tip on the 500ftz and the link to the manual i will look out for one
