MZ30 flash compatibility
rethiking
Posted 22/09/2006 - 21:31 Link
I have recently bought a second hand MZ30 with a 35-80mm lens and would like to buy a flashgun.
The manual lists several (AF201SA,AF220T,AF330FTZ,AF500FTZ), are these the only ones the camera will work with? Some messages in these forums mention the AF400FTZ for instance, which the model name implies is a model between the AF330FTZ and AF500FTZ. I ask this because although these aren't too expensive on ebay finding one that is one of the exact models listed in the manual is a bit of a pain, and I want a genuine Pentax flashgun to avoid any compatibility issues.
George Lazarette
Posted 22/09/2006 - 22:59 Link
All Pentax flashguns will work with your camera.
Mannesty
Posted 23/09/2006 - 09:05 Link
As George says, all Pentax branded guns will work with your camera. Some of the functions found on newer guns (AF-360/540FGZ) however are not supported. Wireless flash for instance.
One of the most versatile Pentax guns I have used is the AF-280T. It lacks trailing curtain and high speed synch, nor does it offer focus assist but otherwise its an excellent gun with a bounce and swivel head, TTL and manual modes.
One very important question you must ask about second hand flashes is the condition of the battery compartment and its cover. Many occasional users often leave batteries in them which eventually leak and can cause significant corrosion.
There are of course many third party flashes having Pentax dedication which will also work with you camera but my recommendation is to buy Pentax.
