Mysterious spots
1. Very small bright spots are failed pixels, only noticeable against a dark background, and
2. Much larger greyish spots are caused by dirt/dust on the sensor, which can usually be blown off, but might ocassionally require wiping or cleaning. These are part of life if you own a digital camera, unless you keep it in a vacuum.
New Jersey, USA
Pentax ist DS 18-55mm, Sigma 28-200mm F3.5,Zenitar 16mm
I can only hope that later generations of Digi Slr's are better containing this.
Many Thanks Alistair.
I find that my Pentax ist DS stays clean if I adhere to two rules. Change lenses only when the camera opening is facing down. And try if possible to change lenses in a dusty or windy environment.
Andy
Andy
New Jersey, USA
But it's not that difficult
Andy
http://www.intemos.com
Is this a good idea, or should a great deal of caution needed.
Personally, after almost a year, I have found no dust spots at all, and as long as that holds true i won't be thinking about sensor cleaning.
Like lens cleaning, only do it if you have to.
many thanks.
Andy
23 years
Perthshire
On certain shots I see spots on the photos.
This tends to be on lowershutter speeds or on AP, and possibly SP, setting.
What I can't understand is that it's not every shot this happens.
I have a fried who has a D50 Nikon.
It's been sent back to get cleaned (Sorted) 3 times, and it's still not correct.
He even went to the extent of buying a 28-300 lens so as not to have to change the lens at all.
Surly this is the not good for Semi-pofessionals or serious amateurs.
What can be done, to sort & or prevent this.
