my xp wont detect my k10d
Posted 20/10/2008 - 18:40
Hi Philip,
get yourself a card reader, and just use that to download your picturwes direct from the card.
Liam
Liam
Liam
Posted 20/10/2008 - 19:15
Hi Philip,
As LiamD has said use a card reader it's better and faster, also while updateing your Camera software You could update your Raw Codecs as well, Adobe Camera raw 4.6 (www.Adobe.com) and Pentax site for the Pentax Raw, While your on the Adobe site there is a DNG 1.2 codec for Windows so you can see Raw files in windows Pic/Fax.
Hope this helps
Hope this helps
Tel,
Posted 21/10/2008 - 01:48
xp sp3
Posted 22/10/2008 - 14:40
I mean do the codecs work with XP? I thought they were just for Vista.
~Pete
Posted 22/10/2008 - 15:55
the problem is a conflict usb vs k10d new softweare camara
Posted 22/10/2008 - 20:45
Service Pack 3 for XP appears to have some glitches. At least at work we were advised not to install SP3 on the office machines. If you have SP2 installed earlier, I would try to uninstall SP3...
Terry
Terry
Posted 22/10/2008 - 21:11
As I recall SP3 initially had issues with some anti virus programs and also trashed something and was withdrawn and then reissued. For the little it's worth both my PCs have SP3 on now and seem fine and recognise my K10D just as before.
I'm not sure if it's possible to uninstall SP3.
Posted 22/10/2008 - 21:24
Only by wiping the machine and reinstalling everything from scratch.I'm not sure if it's possible to uninstall SP3.
Best wishes, Kris.
Posted 22/10/2008 - 22:22
... or just wiping the C-drive, all your data, music, pictures etc. residing safely on your other disk partition(s)
Terry
Terry
Posted 23/10/2008 - 07:19
However, let's not be gloomy as this isn't the problem. I think the s/w has installed some drivers that hijack the USB connection to the Pentax so that the often repeated advice of getting a card reader should work fine.
Also SP3 seems not to have done anything bad to my PC's which is a relief.
Posted 23/10/2008 - 08:21
thank for yours help, but i think that the problem is not in sp3, the problem is in the upgrade of the k10d because in my 2do pc i have the problem without sp3.
thanks philip
thanks philip
THANK FOR YOu help
philip
