Monitor calibration
Posted 19/02/2010 - 10:23
If you use Photobox for prints, they certainly used to send a calibration print of their own tp you, alongside which you download the electronic version from them to show on the screen and 'tweak' monitor accordingly to match up!
I use a Spyder, and it has set the screen a bit darker than without the calibration - and this did result (lo and behold) in the prints coming off printer looking more accurate !
have you tried printing off with your adjustments and simply comparing print and screen?
Lets see what others suggest as ell
Andy
Andy
Andy
Posted 19/02/2010 - 10:31
Andy
Now, you see; that would have been too easy have you tried printing off with your adjustments and simply comparing print and screen?
Andy
No, didn't think of that Will do that tonight when I get home.
Posted 19/02/2010 - 11:03
Posted 19/02/2010 - 11:10
Sorry, should have said. Mine is a CRT monitor.
But thanks for the link, I can check my monitor in work.
Wirral
I ran the software and corrected the Gamma, brightness and contrast, following the instructions.
Now my photos look somewhat darker. Is there a "Test Card" or something similar I can download to check my setting against?
I knew I should have left well alone
