Monfrotto Tripod
Posted 02/02/2010 - 16:41
I'd say 4kg is ample for your K20D and most (if not all) lenses you'll ever use it with. By the time you get to lenses that weigh more than 2-3kg then you're in the realms of the super-telephotos that cost as much as a small car and you'll probably want a dedicated gimbal-type tripod head with them anyway.
Joining the Q
Posted 02/02/2010 - 16:44
It's down to you I'm and pan head man my self with a 804rc2 x2
I to own a k20d and the tamron 70-300mm f2.8 and a Grip and I wouldn't put any of my kit on a ball head but that is just me
James
James
Posted 02/02/2010 - 17:12
The Manfrotto ball head I had with my Bembo was absolutely fine (until one of my crew managed to loose it ) and coped happily even with a medium format camera. I prefer a three-way head though as I find it easier to get level but that is really down to your style of photography and personal preference.
K.
K.
Posted 02/02/2010 - 18:17
Thanks chaps
I will try using it and an added bonus is the tripod and head they sent me is about £40 more expensive than the one I ordered
Lee
Lee
Lee
Posted 02/02/2010 - 18:19
I am not sure about the 494, but I suspect it replaces the 484 which I have. I have K10D plus the tamron 70-300. It is ok, but not as rigid as the pan and tilt head (ie have experienced some very slight shake with it). I also experienced a bit of 'creep' when I had the camera in portrait mode - ie 'hanging' to one side on the ball joint - however that could be my error. I am a bit torn as the 484 is relatively light to carry around when on a long walk, but I imagine the 486 being heavier is a bit more substantial and rigid.
Hope that helps
Andy
Hope that helps
Andy
Andy
Newcastle Upon Tyne (Forest Hall)
I would like some advice please.
I have ordered a tripod for the first time as I am just starting out with my K20d.
I ordered a Monfrotto 190xdb + 486rc2 tripod kit for general landscapes etc and they sent me a 190xprob with an 494rc2 head.
I have had a little look at the 494rc2 on-line and it said it can take up to up to 4kg. I know the camera is only 750g and my tamron 70 - 300 is not that heavy. Do you think I should send it back or will I be ok to use the head with the k20d safely?
Lee
