Mini SD Memory card Error.
Posted 11/09/2006 - 13:08
Not sure, but you may need a firmware update in the Optio to support larger cards
Posted 11/09/2006 - 13:09
Hi, and welcome to the boards..
I think you'll probably find that that model doesn't take a 2 gig card. I had a quick look and only found mention of a 256 mb card as an optional extra, which may be the biggest you can use. I stand to be corrected by someone who knows what they're on about of course..
EDIT: and Matt'll be that someone.. posting while I'm typing..
Liam
Liam
Liam
Posted 11/09/2006 - 13:23
Just checked the Optio 50L manual
Page 77 has the specs, and it mentioned "Up to 1Gb". Some models have had updated firmware to support cards of 2Gb and the higher spec'd SDHC (4Gb+) - but I couldn't find anything on the 50L at the moment.
Sorry that isn't such good news
20 years
Any Ideas gratefully received.
