Metering with 1.7X converter
mille19
Posted 14/07/2007 - 17:26 Link
I am having problems with the metering on my K10D with a Sigma 100-300 EX F4 lens and Pentax 1.7X converter.
I have taken some test shots and found the following:-
With the camera set to AV and lens in A position at F4 the camera meters at 1/80th second.
With the camera set to M and lens at F4 using the ring the camera meters at 1/320th second.
Both shots were correctly exposed.
I have also noticed that in AV mode I can set the F to F2.8 but the lens is only a F4 if I take a shot at F2.8 the shots come out over exposed.
Has anyone else had the same problems and has anyone any ideas why this could be happening?
ChrisA
Posted 14/07/2007 - 17:45 Link
I've had the same issue using a Pentax SMC-A 400mm lens with a Jessops branded 2x AF teleconverter.
George Lazarette
Posted 14/07/2007 - 17:48 Link
I don't understand your last paragraph. Please recompose. Earlier, you mention using "the ring". Don't. The K10D works best when the aperture is set from the body, with the aperture ring set to A.
mille19
Posted 14/07/2007 - 18:02 Link
Sorry it is a bit difficult to explain.
What I meant was when I use Aperture Priority mode I can set the aperture to 2.8 on the camera but the lens is only a F4 lens.
I was only using the ring on the lens to prove a point why do I get two different meter readings for F4 surely they should be the same.
George Lazarette
Posted 14/07/2007 - 18:42 Link
You should not be able to set f2.8 on the camera when you have a max aperture on the lens of f4.
I suspect that either you have a fault somewhere, or dirty contacts. Try cleaning all the lens-mount contacts on each item. This can often be a cause of exposure errors.
mille19
Posted 14/07/2007 - 19:14 Link
Did you find a solution?
George Lazarette
Posted 14/07/2007 - 19:19 Link
Clean your contacts!
Ammonyte
Posted 14/07/2007 - 19:40 Link
Does the teleconverter have all the relevant contacts?
Tim the Ammonyte
K10D & sundry toys
George Lazarette
Posted 14/07/2007 - 19:53 Link
It has all the contacts that a Ka lens has, as I understand it.
I have just put an FA zoom on my K10D, with the 1.7 TC and everything works perfectly. The zoom has a widest aperture of 1:4, and the body would not open wider than 1:8. With a 1:1.8 lens, the widest allowed aperture was 1:2.8. Note that this represents the combined aperture of the lens and the TC.
George Lazarette
Posted 14/07/2007 - 20:06 Link
In fact, as an F lens,the TC should have all the contacts that a Kaf lens does.
Ammonyte
Posted 14/07/2007 - 22:00 Link
Ok, 'twas just a thought.
Tim the Ammonyte
K10D & sundry toys
George Lazarette
Posted 14/07/2007 - 22:23 Link
If it weren't for thoughts, we'd still be in caves.
Ammonyte
Posted 14/07/2007 - 22:37 Link
ROFL
Tim the Ammonyte
K10D & sundry toys
ChrisA
Posted 15/07/2007 - 01:40 Link
No.
What do you think I should do George? I thought I might try cleaning the contacts.
George Lazarette
Posted 15/07/2007 - 12:58 Link
No.
Now there is a novel idea! But does the Jessops TC have contacts?
