metering mode selection
Posted 01/05/2021 - 16:04
Cant speak for K70, but the KP does not have dedicated button for metering. You can customise the function of most the buttons so you can set another button to to do the job. The Quick menu is customizable so you can set it to be one of the options in there (if its not already one i cant remember). I opt for the latter and find that works for my needs
Posted 01/05/2021 - 22:49
thanks punkrockemo, much appreciated for KP - so It's possible if the function dial is set to AE ?
Is it possible to assign metering mode to fx1/2/3 ? I downloaded the manual and as far as I can see it's not ? Has it been changed via firmware update perhaps ?
cheers
cheers
Posted 02/05/2021 - 11:01
Sorry I made a mistake, I thought that metering mode was one of the options for the FX buttons but it's actually meter lock.
I forgot that it can be changed by smart dial. I rarely change my smart dial from ISO
Posted 02/05/2021 - 15:26
no worries punkrockemo, thanks for taking the time to respond to a query, much appreciated
Posted 02/05/2021 - 15:28
Looking at K70 downloaded manual, to change the metering mode requires entry to menu system and modification from there, now way to change via a function button or a dial ?
Posted 02/05/2021 - 16:34
No dedicated button but the quickest way on the K70 is to use Info button.
Paul
Posted 02/05/2021 - 22:14
Aha, thanks PRYorkshire
Posted 03/05/2021 - 11:10
cheers
On the kp you can set the function dial to AE, then dial in your choice, multi or centre weighted or spot. I played with it once but now I must have changed it!thanks punkrockemo, much appreciated for KP - so It's possible if the function dial is set to AE ?
cheers
I recall seeing it change in the viewfinder
I have gone through the settings and you can't IMHO set up this to a function button.
I have a K5, on which there is a separate lever to choose between spot, centre weighted and full metering mode options
K3 Mark1 and K1 have a dedicated button
Is there similar functionality on the following and how does it work ?
KP
K70
thanks
