mercury battery replacements for meters
Posted 03/10/2007 - 10:44
Posted 03/10/2007 - 10:55
As far as the Pentax meters are concerned, there is no problem using silver cells or indeed alkaline ones. Pentax used a bridge circuit which effectively compensates for the slightly higher voltage. For meter which use a linear circuit, the higher voltage wil cause a problem and unfortunately the exposure "difference" is not linear so you cannot compensate using a different ASA setting. They will tend to read the same at low EVs and the difference will be greater at high EVs. Wein cells work but are very expensive and only last about 6 months once activated. Hearing aid batteries are the same chemistry but dry out quicker. However, if you block off all but one hole, they wil last nearly as long as a Wein and a pack of 5 or 6 is less than a quarter of the price of the Wein cells.
Places like the Small Battery Company do sell adapters but these can cost about £20. and will only work for low current devices. Some cameras and meters ask for higher currents than these can deliver. I know someone who makes his own but was selling them for a couple of £'s. Unfortunately the EU has stopped this because of the new rules on using solder with lead in it.
Other alternatives is to adjust the meter so that it will take silver cells or to fit a shottky diode which will drop the voltage of a silver cell to 1.35v. For these solutions and the adapters, you must use silver cells as they have a flat discharge curve unlike the alkaline ones which have a marked slope.
Kim
Kim
Posted 08/10/2007 - 09:54
For "in camera meters" I might agree with you but surely the only real purpose of buying a handheld meter especially a Gossen is to get accurate exposures.
Kim
Kim
Maybe I'm overly gung ho, but when shooting BW negatives I tend to take the view that a stop here or there doesn't really matter. Sunny16 is fine most of the time too. If you're shooting slide, it's a different matter of course.
22 years
GB
I'm about to buy a lightmeter (Gossen Lunasix 3) but it was designed to use a 1.35v mercury-based battery. These are now banned. for whatever reason there is no direct equivalent, except for zinc-air cells which don't last that long. All other replacements have higher and (in some cases) variable voltages.
I gather that some older bodies would have the same problem, does anyone know the best way around this? As I'm only paying around £30 for the meter I can't justify another £30 or so for a voltage adapter. How badly is the meter thrown by different voltages?
All comments gratefully received
