Memory Cards in Pentax Cameras
Posted 07/09/2005 - 15:15
Apparently, someone has greased the palms of some camera makers to push the new SD format card. I'm hoping that when the D2 comes out, it will take Compact Flash. That's what most of us have, and most professionals use them.
I do know that Lexar's Write Acceleration technology works with the *st D, it speeds things up considerably!! I have no idea if they make SD cards, and hopefully won't have to.
Olympus once had a DSLR that took two kinds of memory cards. Pentax could solve the delimma by outfitting the next digitals the same way, with both CF and SD cards. That would make the transition less painful, if that's where the industry is gong!
Posted 07/09/2005 - 15:18
Why not try to get a spare D body whilst they are still available at about the same price as the DS? As to the cards, I have found the major difference is the speed that you can transfer the files to the PC but this doesn't worry me so I tend not to use the ultra fast cards.
Kim
Kim
24 years
I know that faster cards have been released which might judtify buying new cards and changing format at the same time, but I have found no difference shooting in RAW format on my camera using a standard 512 Mb memory card from using a 40X Lexar card. (Although I must say that the *ist D is much faster than the Fujifilm camera was with the standard card - is the limiting factor the camera or the card?) Could this agree with the Which? magazine tests on Memory cards that found little difference when using different speed cards? ... - but that's a completely different point!
