Memory Card Error K10D
Posted 23/09/2011 - 12:17
I would imagine if the internal switch was stuck the message would be 'memory card locked'
Have you tried removing the battery to effectively reboot the camera and/or resetting to factory defaults?
Posted 23/09/2011 - 12:25
Yes we have tried both those things. Any more ideas?
Posted 23/09/2011 - 12:29
Sadly, no I don't but I'm sure someone else will come up with more suggestions.
Posted 23/09/2011 - 12:30
Just a thought, you could try re-installing the firmware.
Posted 23/09/2011 - 12:43
I thought you did that via the memory card KenJust a thought, you could try re-installing the firmware.
Have you tried switching the camera on without a card in? it should say "no memory card" it could be a way of determining if the cards are at fault, if the error message still reads memory card error with no card in then it odds on the fault is with the camera.
Posted 23/09/2011 - 12:51
Sometimes when we get a card fault, the card will work in one camera but not in another identical one. So we get the images off via a card reader, or via the camera if that's all that works, and then discard that card. The images are the imprtant thing, so a new £5 card is neither here nor there.
If the cards are any particular age, the a new one may be OK. Also, don't forget to format the card in the camera every time you want to delete all the images. If you don't there is a small risk of card failure.
Hope that helps!
Hope that helps!
Posted 23/09/2011 - 12:58
Doh!
Posted 23/09/2011 - 13:08
Fatspider, it says No Memory Card when you switch it on without a card.
We have tried several different cards of different brands.
Posted 23/09/2011 - 19:17
So can anyone tell me a decent repairer please? Preferably local to Yorkshire.
Posted 23/09/2011 - 19:36
The obvious choices are JP Service Solutions, Asahi Photo and Harrow Technical.
The first one gives 20% discount to PU Plus members.
Posted 23/09/2011 - 19:45
Thanks John.
Posted 23/09/2011 - 21:25
hi jay
have your friend tried this shop
http://www.dalephotographic.co.uk/mall/productpage.cfm/DalePhotographicOnline/_C...%20REPAIRS/142543/Camera%20Repairs
neil
neil
cheers Neil
pentax k3
Panasonic Dmc Fz200
pentax k3
Panasonic Dmc Fz200
Posted 24/09/2011 - 11:23
I bought a K10D with a similar error for not much- thinking it wouldn't be that hard to fix. Turned out to be dry joints on the inter-board connector between the motherboard and SD card board.
Trouble was that in taking the two boards apart two tracks got broken on the PCB because there wasn't enough mechanical strength left with the bad joints not holding. Now I've got a K10D in pieces, but broken and without much chance of a fix
It may well be something similar on yours
Posted 24/09/2011 - 15:05
gtis wrote:
hi jay
neil
Hi, my mate went today buy apparently it's shut down.
hi jay
neil
He was shooting some outdoor shots and when he took the last one it gave a message saying that the image failed to save and after that all he got was memory card error.
I have read somewhere that there is a switch inside the memory card holder that detects if the memory card is set to locked or not and that this switch can sometimes stick in the locked position and can be freed with a prod with a cocktail stick.... is this true?
In the worst case scenario and it's a hardware issue where is the best place to send it (Yorkshire area if possible,) my mate isn't working and cannot afford expensive repairs by Pentax etc...
Thanks for any advice.
Jay
