ME Super metering fault
Posted 02/07/2005 - 18:20
Hi Peter,
My ME Super is the same. If I don't use it the metering is unreliable but a good twist of the film speed and / or exposure compensation dials does the trick.
I'm no expert but I guess the contacts on the other end of the dials get corroded and moving them clears the contact. Dust, dirt and condensation when you breath with your eye at the viewfinder!
Posted 02/07/2005 - 23:12
Yes, I've had this in the past - with an ME Super and MEF.
The ASA/ISO dial is not dust proof. It is a small rotatary potentiometer (variable resister). Over time grit and dust gets in there and increases the resistance. As a result the exposure reading goes awol.
For both my cameras I managed to get hold of a service manual, and bought spare dials direct from Pentax. Fixing it myself was a bit of a pain in the neck, but kept them going for quite a while longer.
In the end you will need to replace the variable resistor (although you can clean it with some good results). I suppose it wasn't the greatest design...
Hope that explains it.
Posted 25/09/2005 - 14:22
I jus found this thread after posting and receiving helpful replies on the "Troubleshooter" section. This may be what has happened to my MEF which has been underexposing. I'll give this a try!
Aaron
Aaron
Posted 25/09/2005 - 18:59
I tried it, and it worked. I wish I knew this before, as over the years I've had this problem crop up and spoil some shots. Are the manuals and parts still available?
Posted 29/09/2005 - 12:02
You can download a copy of the MES repair manual from Mark Roberts site at http://www.robertstech.com/pentax.htm. As far as I am aware Pentax doesn't support the MES anymore and doesn't stock any spares. You could try Robin at Harrow Technical at http://www.harrowtechnical.co.uk/ or if you want the camera serviced, I would try Mike Spencer at http://www.btinternet.com/~camerarepairer/
Kim
Kim
Posted 07/10/2005 - 18:13
Thanks for the help and the links. I really like the MEF, and hope to use it a long time.
21 years
Brentwood Essex (UK)
