Macros with Ring Flash
- Edit Lock Enabled - You will not be able to edit/delete your posts in this topic.
Posted 23/08/2008 - 23:26
Posted 23/08/2008 - 23:41
That looks just like my setup
amazing Whats with the GPS though :
Camera:|K-7|
Posted 24/08/2008 - 11:36
Clarky wrote:
I'm a little surprised you can use it on the 180 without any vignetting, I haven't tried my AF-080C flash on my 180.
The AF140C is 58mm, the same diameter as the front element of the Sigma EX 180mm Macro. Even though the 180mm has a 77mm filter thread, the glass is still only 58mm, hence no (or very little) vignetting.I'm a little surprised you can use it on the 180 without any vignetting, I haven't tried my AF-080C flash on my 180.
I attach mine using a 77-58mm step down ring and the 58mm ringflash holder.
Posted 24/08/2008 - 11:49
The AF-080C is only a 49mm, a little to far to step I would suspect :
The Sigma 180 has a 72mm filter, well i'm sure mine does anyway
Camera:|K-7|
Posted 24/08/2008 - 11:57
Mike-P wrote:
What happened to the rest of this thread?
Strange things are happening on this forum.What happened to the rest of this thread?
Posted 24/08/2008 - 11:58
George Lazarette wrote:
Strange things indeed.
Camera:|K-7|
Posted 24/08/2008 - 12:09
Unfortunately the original poster decided to delete the opening post, which has made this thread slightly odd. I would suggest that this is not a very good idea with any thread as it undermined everything that followed. :
Posted 24/08/2008 - 12:11
I can't see the point of it to be honest
Camera:|K-7|
Posted 24/08/2008 - 12:53
He's gone back to the digital darkroom to take on board Clarky's advice. Soon new, high-contrast, dragonflies will be buzzing round the forum.
Posted 24/08/2008 - 13:54
Why is this even allowed?Unfortunately the original poster decided to delete the opening post, which has made this thread slightly odd. I would suggest that this is not a very good idea with any thread as it undermined everything that followed. :
Cannot the forum be made so that once someone else posts below the original the option to delete is taken away?
Posted 24/08/2008 - 14:02
I'm sure they can, but by removing the option to edit as well.Why is this even allowed?
Something of an own-goal for the OP, methinks.
Sydney Australia
I'm a little surprised you can use it on the 180 without any vignetting, I haven't tried my AF-080C flash on my 180. Its smaller than the macro lite at 49mm, that a big stepdown :
I took some liberties with yours, just added a little contrast.
[IMG]http://i184.photobucket.com/albums/x261/ClarkyinAus/chirpysbug.jpg[/IMG]
