Macro bits
Donut
Posted 22/01/2008 - 18:32 Link
I have managed to pick up a set of Vivitar Automatic Extension tubes, a Soligor 49mm reversing ring and a Aico Pentax mount bellows to go with my existing kit of: -
K100D with kit 18-55
Tamron 70-300 Macro
SMC Pentax A 1.7 50mm
Vivitar MC 24mm f2.8
2X KAX Macro teleplus MC7 (which is a great piece of kit) and
Pentax 1.4X-S Converter.
Now I'll get to the point.
What is my best bet for Macro photography. I guess the extension tubes and bellows would produce similar image quality as neither have any additional glass. If these are going to be worth a try how do I deal with setting apetture and shutter speed as clearly the camera won't have a clue what's happening with the lens. What about the reversing ring on the 50mm? I will get round to experimenting - which is easy to do with the digital but a few quick pointers would be useful.
An unrelated question - should I be able to get my kit lens to autofocus using the 1.4X-S converter or is it too old to allow this function. I appreciate it won't work with the tamron due to a lack of light getting in.
Thanks for any advice.
Donut
iceblinker
Posted 22/01/2008 - 19:13 Link
With a reversing ring or manual extension tubes, I just use trial and error. It only takes a few tries to home in on roughly the exposure I want, even when starting with a pure guess, then it's just a matter of fine tuning.
I've had autofocus working fine with a Tamron 70-300mm LD Di at 300mm with a 1.5X Kenko converter. I've not tried it with an 18-55.
~Pete
Donut
Posted 22/01/2008 - 21:32 Link
Thanks Pete - it seems as thought he Pentax 1.4X is to blame then - must be manual only
Donut
iceblinker
Posted 22/01/2008 - 23:15 Link
I've just found the spec of your converter here:
www.bdimitrov.de/kmp/teleconverters/A1.4X-S.html
I can see it doesn't have the slotted screw that would be needed by a standard autofocus lens for AF to work. Remember the focusing is powered by a motor in the camera rather than in the lens (except for the K10D with the new mega-expensive lenses). So a physical connection is needed rather than just an electrical one.
I was lucky to find a Kenko AF 1.5X cheaply on ebay a while ago. I think the quality is reasonable.
~Pete
Unlocker
Posted 23/01/2008 - 02:23 Link
Being shooting some macros today with 3x Auto Extension Tubes, and my DA*50-135mm on the end.
Got some damn fine results and think I have stumbled on a simple way to focus when in that close (compared to a 50mm prime that most people seem to use!), just use the zoom. Hey presto, no more trying to move the tripod 1.26mm to get in focus!
Donut
Posted 23/01/2008 - 10:53 Link
Focusing manually tends not to be a problem - I just half press the shutter release and turn the focussing ring until the camera bleeps and a confirming square appears in the view finder
I was messing about with the bellows last night for about 5 minutes - soooooo much light loss. I'll need to use some really good lighting to be able to get the most out of it - may not bother as the K100D won't fir directly onto it anyway - I need to use a short extension tube as the camera catches on the mount of the bellows.
Donut
