M50 f4 macro on K5
Posted 28/04/2012 - 19:25
John, with the lens not attached to the camera, is the aperture opening and closing when you turn the aperture ring? If so, there's nothing wrong with it, if not, it is faulty.
Posted 28/04/2012 - 19:46
When you turn the aperture ring nothing happens. It only stops down when you push the lever on the side down and feels sort of sticky. It will not snap back.
Pentax K5, Kx, DA15 ltd,18-135, 18-55, 50-200, M100 f4 macro, M135 f3.5 A28 F2.5
Posted 28/04/2012 - 21:49
It is faulty, send it back. Most likely it has oil on the aperture blades.When you turn the aperture ring nothing happens. It only stops down when you push the lever on the side down and feels sort of sticky. It will not snap back.
Posted 28/04/2012 - 21:51
Faulty, send it back.
Posted 28/04/2012 - 23:35
If the return postage is more than the cost. Chalk it up to experience and have a try at stripping and cleaning the insides. It can be done, even with fingers like popeye (mine) if you proceed carefully.
Otherwise send it back as suggested above, would agree with David's analysis.
Bernard
Bernard
Turnberry,
Ayrshire
