M37 to k mount adapter
Posted 25/06/2016 - 07:48
I'm sure they exist, and if properly engineered there's no need for any light leak.
However, 37mm thread lenses are probably for rangefinder cameras and the back focus will be too short for a DSLR. This would mean no infinity focus, so close ups only. If lens elements were added into an adapter then infinity focus might be possible, but perhaps with loss of quality.
Posted 25/06/2016 - 07:54
Weren't M37 lenses for SLRs around before M42 lenses? The size had to be increased to allow newer, faster lenses to be used.
I've never come across an adaptor, but then, i think I've only ever come across one M37 lens in my years of acquiring photographic equipment.
Edit: yes, M37 was pre-M42. I found some links which could be useful. The second one is a French company selling adapters, though obviously I don't know if light will leak.
http://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/173206-asahi...
http://www.labaguephoto.com/en/adapter-ring-various-mount/489-m37-mount-adapter-...
Posted 25/06/2016 - 08:49
The Asahiflex to Pentax M42 adapter was available in the early days of the screw thread cameras. I think Asahiflex was M37 as well.
Posted 25/06/2016 - 09:48
I use an Asahiflex 50mm lens with the 37 to M42 adapter.
The adapter is or was available on Ebay.
The light leak is not the fault of the 37 mm adapter,
There are 2 reasons, why the light leaks.
1.) the 42mm to K adapter has 2 slots on the side, to be able to remove it again.
2.)This does not matter with the Takumar or similar lenses, But the Asahiflex lens has a smaller back and does not cover the the adapter completely.
I fitted a black rubber or Neopreen ring on to the back of the lens. This fixed the problem.
The50mm Asahiflex lenses are well made and very sharp, due to its Tessar copy design.
Regards, Horst
Regards, Horst
Posted 25/06/2016 - 09:54
Here is the Ebay number for a 37mm to M42 adapter. this is from the USA.
172065622736
Regards, Horst
172065622736
Regards, Horst
Posted 25/06/2016 - 14:50
Thanks to everyone who posted.
Its good to know that the Takumers are not affected by light leaks.
I think its nice to add some legacy lens as well as modern lens.
I will follow the links.
Posted 26/06/2016 - 02:45
Johnreiley wrote:
Same looking and type of lens, but with the larger mount.
I had on of these, but stupidly sold it.
Regards, Horst
John, this is true, however the latest models of the Asahiflex cameras had also a M42 mount.The Asahiflex to Pentax M42 adapter was available in the early days of the screw thread cameras. I think Asahiflex was M37 as well.
Regards, Horst
13 years
Also i understand that an m37 to m42 adapter attached to an m42 to k mount adapter allows light to leak . Is there a specific set up that would avoid this .
