LX Power Issue
There's bound to be someone here who knows the answer.
For my part, I don't know the LX at all but I would start by checking the battery terminals for any sign of corrosion/staining as this is very likely to hinder a good contact.
IF, IF there is any proceed with caution. I would suggest gentle stroking with a stiff pen brush (I'm thinking of one usually used for cleaning printed circuit board tracks and have fine bristles of glass fibre - try Maplins). Be careful not to let the debris enter the camera.
regards
Bernard
Terminals are nice and clean and I thought the same as regards battery orientation- so I tried both ways without success. There is a little illustration of the correct way to insert the batts i.e. with the +ve sign visible viewed from the bottom of the camera. No joy I'm afraid.
Bob.
Drop the batteries in place (leave off the lid) then prod the test leads onto the top battery and case and measure the current being drawn, if any. No current drawn suggests the on/off switch (at least) or a faulty circuit board(s)
Do the batteries retain their charge or does the camera flatten them - flat batteries suggest a larger than normal drain so suspect a circuit problem.
Bernard
If the meter lights up in the viewfinder then that would imply that there is power there - move the winder to the stand-off position and half press the shutter to check if you get a reading.
Checked with a multi-meter and no current appears to be flowing (batts check o.k.)
Absolutely no sign of power getting to the camera.
Camera does fire at X- speed so mechanics are o.k.
Looking into the battery compartment there is a steel side terminal to pick up the +ve edge of the battery but at the bottom of the compartment there just seems to be a dark grey soft pad which is presumably the negative terminal?
Not sure how this works though unless it is some sort of graphite material.
Anyone able to advise me if this is correct or should there be a secondary steel terminal across the base of the compartment?
Bob
K.
At the bottom of the battery compartment there should be a steel sprung terminal which connects with the negative of the batteries. It is bright and shiny in my LX and easy to see, occupying almost the whole of the bottom of the compartment. Sounds as if you are missing a part.
K.
[IMG]http://i1236.photobucket.com/albums/ff444/Frogherder/IMGP6473.jpg[/IMG].
May not be exactly the same as this is my old Minolta camera
regards
Bernard
K.
Bernard thanks for the photo- mystery solved. Not sure if this is better or worse than an electrical fault but at least I can see the light at the end of the tunnel.
Bob
I'm new to the forum and just decided to revisit film photography of my youth by kitting out with an LX + prime & macro lens. Bad start I'm afraid though as my LX won't power up. I have replaced the batteries but still as dead as the proverbial. Anyone any idea of the problem? and most important is is repairable?
Bob
