ltd lenses
pink
Posted 04/10/2010 - 09:46 Link
Just a quick question
does a telephoto lens have a larger point of view than a prime
The reason my studio is limited in length and I am struggling to get full length shot and keep it within my three meter back drop?
James
My Fluidr
i-Berg
Posted 04/10/2010 - 10:11 Link
The longer the lens (in focal length terms), then the less you see James.
A telephoto is generally a longer focal length lens, so the answer to your question is no, assuming you're comparing it to a lens of a shorter focal length.
I was intrigued when I saw your thread title - what was the issue with Limited (ltd) lenses? Was that an additional question?
Edited by i-Berg: 04/10/2010 - 10:11
pink
Posted 04/10/2010 - 10:26 Link
I'm looking at a 44 ltd and just wondered if at 44 on a telephoto was the viewing angel is the same
James
My Fluidr
Edited by pink: 04/10/2010 - 10:26
i-Berg
Posted 04/10/2010 - 10:32 Link
Are you referring to the Pentax Ltd 40 mm pancake lens James?
If so, what are you comparing it with? What are you using now?
Edited by i-Berg: 04/10/2010 - 10:32
Dangermouse
Posted 04/10/2010 - 10:34 Link
"Telephoto" just refers to a longer lens - generally anything over 50mm is a telephoto while anything under that is wide angle. 85mm for example would be considered a short telephoto.
The field of view of that 43mm Ltd when fitted to a DSLR would be similar to that of a 65mm lens on film. Most people seem to want around the 50mm/55mm mark as a portrait lens on digital, although it depends on the portrait you want.
womble
Posted 04/10/2010 - 10:40 Link
I think what James is trying to ask is this:
To get a full length portrait in his studio he is using a wider angle lens and this results in getting stuff in his shot above/below his backdrop. If he was to use a longer focal length lens and step back a bit would he avoid this problem?
Instinctively I would say yes as the angle from the lens past the top of the models head to the backdrop will be shallower with a telephoto than with a wide angle (assuming you adjust your distance to keep the model the same size in the frame).
As to the 43mm Ltd, 43mm is 43mm is 43mm. The angle of view should (if the manufacturer has been truthful) be the same on the 43mm Ltd and for any zoom (e.g., the kit lens) set to 43mm. IQ is a different story.
K.
pink
Posted 04/10/2010 - 11:01 Link
Thank you k
that it
so no the view angle is the same on a prime as it is on a zoom that all I wanted to know so I'm going to have to move my desk around for full hight shots thank you all for the input
James
My Fluidr
rparmar
Posted 04/10/2010 - 12:55 Link
Just buy the FA43 Limited and change your life as much as you need to to suit it. You will be glad you did.
Listen to my albums free on BandCamp. Or visit my main website for links to photography, etc.
womble
Posted 04/10/2010 - 19:31 Link
pink wrote:
Thank you k
that it
No problem.
I don't get nearly as much use out of my 43mm Ltd as I was expecting I would. I use the SMC-M 100mm f/2.8 and the SMC "K" 135mm f/2.5 much more. I do like the Ltd on my KX/LX/MX though.
K.
rparmar
Posted 04/10/2010 - 23:06 Link
Well, it does depend on what focal length you prefer, of course. But OP was talking about 43mm so it's a safe bet he doesn't want 135mm.
If you want longer than 43mm, choose FA 77 Limited.
pink
Posted 04/10/2010 - 23:26 Link
77 ltd is my next lens and then some think longer
James
My Fluidr
Mannesty
Posted 04/10/2010 - 23:53 Link
James
I always think longer.
womble
Posted 05/10/2010 - 09:40 Link
I was talking generally about the "life changing" nature of the Ltds, not as a recommendation to James. Both the 31mm and 77mm are on my wish list, along with an F* 300mm but all will have to wait until I win the lottery or something!
K.
