lost fstop display on tamorn lens
crashmars
Posted 30/04/2012 - 04:47 Link
how is fix what contact
JAK
Posted 30/04/2012 - 12:28 Link
Has it accidentally come off the 'A' setting?
Mind, I'm just presuming it is an 'A' lens - you haven't said what lens it is or if it had been working OK and just gone wrong or if you have recently acquired it and it has never worked!
John
Edited by JAK: 30/04/2012 - 12:30
crashmars
Posted 30/04/2012 - 12:36 Link
alens set on a sometimes i get f stop then goes away as if contact was not working
crashmars
Posted 30/04/2012 - 12:39 Link
this is a tamron AFaspherical LD[if] 28 -300mm macro
JAK
Posted 30/04/2012 - 12:44 Link
If it's an Adaptall 2 mount you may need to clean the electrical contacts on the lens and the actual mount itself as that too is used as an electrical contact.
Well, not Adaptall but still worth seeing if cleaning the contacts helps. Presume other lenses are OK?
John
Edited by JAK: 30/04/2012 - 12:46
crashmars
Posted 30/04/2012 - 12:46 Link
will do thanks
crashmars
Posted 30/04/2012 - 12:48 Link
yes other lens fine
crashmars
Posted 30/04/2012 - 13:03 Link
cleaning contacts gave a f stop just for sec. lost when zoomed lens seems tight when mounted comes back when not zoomed
JAK
Posted 30/04/2012 - 13:11 Link
Is the lens a little loose when mounted on the camera? That may account for the intermittent contact. If you've not had the lens long consider returning it to the supplier as possibly faulty.
John
crashmars
Posted 30/04/2012 - 13:17 Link
ok thank you
crashmars
Posted 10/05/2012 - 18:10 Link
i took this lens off{ a} setting two or three times and returned to {a}now works fine thanks again
JAK
Posted 10/05/2012 - 18:52 Link
Good news. Probably a dirty contact inside the lens.
John
