longer zoom which won
Posted 19/11/2009 - 00:14
you've got your designations backwards there.
I'm not sure if either of those older lenses is noticably better than the Tamron or Sigma APO in terms of sharpness. I would expect the FA 80-320 to be the best of the two Pentax's and being second hand it should be a fairly cheap option.
I presume your budget wont stretch to the newer DA 55-300, which is superior to all the above lenses in almost every respect.
but it does help
but it does help
Posted 19/11/2009 - 00:29 - Helpful Comment
The 75-300mm FAJ has a pleasant character of its own, but is not the sharpest of these lenses. I still prefer it to the tamron though.
The 80-320mm FA is actually an excellent lens and I'm rather fond of the one I obtained recently. Excellent for wildlife.
The 55-300mm DA is also excellent and rather more compact than the full frame lenses.
Posted 19/11/2009 - 06:34
The Sigma 70-300 DG was a dissapointment. Chromatic abberation was visible right through the range. When for instance photographing a zebra it came out black, green, white, green, black...instead of black, white... The APO version is a different ball game. Quality lens at a good price!
2x K10D bodies, 2x FA 28-200 3.8-5.6, DA 18-55, A 50 F2, 50mm Macro, 360 FGZ. Still saving for the 60-250 DA* Also have a Z10 35mm and a K1000 just for fun. IF PENTAX IS THE ANSWER, WHO CARES WHAT THE QUESTION IS...!
Posted 19/11/2009 - 09:31
I think many would also question whether the Tamron's sharpness and IQ are worse than any of the Pentax lenses you've listed. The Sigma (non APO) definitely has the worst reputation of the 4.
Tim
Posted 19/11/2009 - 10:07
suds wrote:
Pentax 70 - 300 FA
Pentax 80 to 320 FAJ
You have the suffixes transposed.Pentax 70 - 300 FA
The 70-300mm is the FAJ version and has no aperture ring.
The superior (IMO) 80-320mm is the FA version and has an aperture ring. This one can be a bit soft at the long end but is good up to about 260-280mm.
Posted 19/11/2009 - 12:05
The Tamron 70-300 is pretty sharp, actually, although the Pentax 55-300 is said to be a generally better lens by its users (better contrast and less purple fringing, etc).
~Pete
Can anyone rate the two lenses i am considering in terms of image quality.
pentax 70 - 300 FA
thanks for the help.
suds
