Liverpool Waterfront
Posted 28/12/2011 - 23:01
Excellent!
Posted 28/12/2011 - 23:23
fatspider wrote:
Impressive Ted, but the water seems to slope up on the left, you must try harder on your second attempt
Dont be silly !..the tide's comming in!
Posted 28/12/2011 - 23:39
Glad you got it sorted. Excellent work.
Mat
K-5 with grip, Pentax Kit 18-55mm, Pentax DA 16-45mm, Pentax DA 35mm, Pentax 50mm f/1.7 M, Sigma EX DC 10-20mm, Sigma 105mm macro, Sigma 70-300mm, Sigma 150-500mm
Posted 29/12/2011 - 08:57
Like it - it's changed a lot since I was growing up there in the 80's.
Generally I like the lighting but would have been nice to have got a bit more light on the Anglican cathedral. Must be difficult to get a time when the lighting is perfect on all the buildings though
Posted 29/12/2011 - 10:04
Great i like it a lot
Posted 29/12/2011 - 11:25
Well done Ted for capturing the beginning of the Mersey tidal bore ..... what ? What do you mean the Mersey doesn't have a bore ?!?
Nice job Ted. Panos of this size aren't easy. Which lens did you use ? The full size version looks impressive - so many changes since I worked in the Custom House (just to the right of the Liver Building). The Liverpool Echo has a new home too.
The Mersey is pretty wide at this point (was this shot from Eastham Ferry ?) and maybe a short tele next time (and ensuring each shot is taken without any vertical movement - which may have caused the 'bore') would give you a better FoV ? Just a thought.
Posted 29/12/2011 - 17:29
Thanks folks.
Yep, I noticed the bore just after I posted it. A quick correction in CS2 will sort that ( you can see the cathedral is leaning slightly too! ).
It was taken with my 28-80 near to its maximum. I took it from Woodside ferry terminal.
Posted 30/12/2011 - 20:31
Well, I've finally put Liverpool straight ( somebody had to )
[IMG]http://i75.photobucket.com/albums/i296/Father_Ted/PHOTOS/LiverpoolPanorama3Upload.jpg[/IMG]
Wirral
I'm not too fond of this format, so I'm not really sure how to frame one correctly, but here's my first attempt.
[IMG]http://i75.photobucket.com/albums/i296/Father_Ted/PHOTOS/LiverpoolPanorama2Upload.jpg[/IMG]
The forum 800 pixel maximum makes it very small, but here's the link to the full size.
http://i75.photobucket.com/albums/i296/Father_Ted/PHOTOS/LiverpoolPanorama2.jpg
