Linux distro for a total beginner?
Good luck,
Lee
Thanks for the suggestions - Mint is a distinct possibility as I have read that is pretty good, but I will take a good luck at the other two that you suggested.
John
There's a choice of window managers. Cinnamon is a good place to start.
Have fun!
Have used Mint - it's a nice distro. Great for old XP laptops! (Though some older laptops can only run 32-bit versions, and not always the latest version)
Have fun!
Thanks, and I hope I will have fun in a good sense and not "fun" in the "bad" sense.
Now the next problem is to choose which machine to install on - could be an old Dell laptop that's currently running W7 Pro (32 bit) very well,[b] or [/b]a new Acer Veriton N2620G nettop Icore 3 that comes with W7 Pro - that's the most preferred option?
OTOH, it arrived today, but DOA because it seems to have had a "bad experience" on the way here with damage to the packaging - and so won't boot beyond the Acer spashscreen. I expect it will be going back next week to be fixed (I suspect just a displaced SATA connection to the disk, but we will see).
The Acer was bought to be the lounge media PC as I (hope I ?) can then use it to control a Linux-based satellite receiver that will connect to an array of sat dishes at the end of the garden - another of the hobbies that I am trying to get back to enjoying .
BTW, I would like to try to get it to dual boot Win 7 Pro and Linux (Mint?) with the latter as the default to minimise intervention at boot-up.
John
Ubuntu Mate without question! The newest distro, with by far the fastest growing adoption rate of any. It is the lightest distro (meaning it puts little demand on the hardware - so will run quickly even on the oldest device), widest range of hardware support out-of-the-box, closest to Windows and MacOS in look/feel (even has themes which replicate Windows, MacOS and others), and is the only distro with a complete 'Welcome' system for new-to-Linux users to help them install the apps they need right up front.
I dragged my wife kicking and screaming from XP recently, and it has transformed her old Core Duo system, and the learning curve was not a problem ( outside of Photoshop -> darktable that is )
Most importantly it has a very active and supportive community and forum https://ubuntu-mate.community/.
It was developed by an experienced Arch and Mate maintainer specifically to support Windows XP exiles (explicitly his various friends and relatives) and was designed to minimise the direct support required. It has the same desktop metaphor as Windows/MacOS and replicates the earlier v10 of Ubuntu, but is entirely modern under the surface.
Full disclosure, I was an early adopter and beta tester 18 months ago, but the reason I recommend it is the level of support. Submit an issue and it will get considered quickly, and you will get feedback. All the bugs I submitted during beta got addressed - even ones that were upstream in mainline Ubuntu, Debian of Mate. Some took over a year but I was kept informed throughout - which is unique. I've been using Linux desktop exclusively since Windows 2000 support was withdrawn and can honestly say that Ubuntu Mate (pronounced /ma-tay/ after the S. America drink) has the fewest compromises of any distro.
Note if you have a Radeon graphics card you may want to avoid the latest kernals (4.4.x) because of a conflict with their driver. But this should hopefully get resolved soon.
You do want to install the 64-bit version (AMD64 vs i386) because darktable - the open source equivalent to Lightroom - runs more effectively in 64bit. (darktable is in the Ubuntu repositories too - another reason to go with an Ubuntu distro.)
PM me if you need further questions answered or help with Ubuntu Mate - or you know where I usually hang out
Suggestion, grab a download for a USB stick and try it out. With USB (versus a Live CD) you can try installing printer drivers and the like to check out everything before you actually install. And it runs much faster than from a CD/DVD.
Thank you very much.
That looks like very good advice indeed - I will take a look at Mate!
John
I would try any other distro which has a 'live' version which can be booted from a usb stick or dvd. I would also use KDE as the desktop unless using any older hardware ( stuff which cannot run XP or Windows 7 well) as it is the most like windows, otherwise XFCE or LXDE perhaps if you have really old hardware. The most likely issue with hardware compatibility is likely to be printers especially if you have an older one, and then take a look at Turboprint if you cannot find a good driver - its commercial software but not expensive and works well (no I'm not associated in any way) I use it because it works! I have converted my wife from Windows 7 to Linux with KDE and honestly she has no real idea its not Windows (apart from the fact I told her but she hadn't noticed before), it looks identical. Once used to Linux (and it is easy and no you dont have to use the command line for anything these days unless you want to) if you really need windows because of some special hardware then run Virtualbox to run Windows as a virtual machine under Linux!
Stuart
I have mint which i downloaded onto a usb stick and run it on samsung nc10 net book which was running xp and it does the job i have not installed it on the machine yet.I tried a few versions and mint was the only one that worked ok the rest would not let me adjust the screen brightness. It does take a while to boot though..
W.London
Yup, I'm finally going to have to install some form of Linux distro on one of my PC's - and then learn how to use it!
First problem is obviously which distro because I've seen suggestions for quite a few of them but don't really know which one to choose so that I don't get so bogged down pee'd off and disheartened that I give up in short order.
I know, at least I think, that a few forum members run some form of Linux, and so I'm asking for your advice as to your suggestions on which to consider and which to avoid?
Thanks in advance.
John
