Link AF and AE on K100D
WJL
Posted 28/07/2009 - 20:40 Link
Hello everyone,
This is my first post. I hope I can explain this concisely. When using manual lenses on my K100D, I have AF and AE points set to link. So, I presume the exposure is read from the centre focus point, as this is the only point which is available in MF.
When I switch to an AF lens I would like to use the full 16 segment average metering and full 11 point autofocus. My query is - If the link AF and AE is still set to linked, from where, or from which point, is the exposure reading taken ?
Thanks for reading this.
K100D, K20D, PKA 50mm 1.7, PKM 28mm 3.5, Tamron 24-135mm, PKAF 18-250mm, too many Tamron MF to list.
pschlute
Posted 28/07/2009 - 21:24 Link
With your manual lenses the only metering mode available is centre weighted, so you AF and AE linked will do nothing with manual lenses. I am not sure about what happens with a modern lens.
edit...see below about spot metering.
Edited by pschlute: 28/07/2009 - 21:41
pschlute
Posted 28/07/2009 - 21:40 Link
With the modern lens:
If you enable "Link focus point and AE" (in the custom menu), the exposure is biased to the area nearest to the auto focus point that the camera selects ( or you select). I dont know if it uses just one of the 16 segments or an average of a few around that area, but it won't use the whole 16 segments.
I dont use this setting at all, and as I said it has no affect at all wit the manual lens as the camera defaults to centre weighted metering. I think you can select spot metering also , but I am not sure.
