Lightroom problem
Thordell
Posted 24/10/2009 - 18:24 Link
I've lost the little cross that closes a window and the dash that sends it to the tray in my Lightroom windows, one moment it was there and then it was gone.
If anyone uses Lightroom could the offer any help please sure it is something so obvious that I am overlooking it.
Jackie H
K7, K20D, istDS, Optio SV, ME
Most used glass
50mm f1.4, 60-250mm, 28-80mm,
Anvh
Posted 24/10/2009 - 18:37 Link
I use lightroom but I've no idea what you're talking about Jackie
Could you make a screen shot where those icons must appear?
Stefan
K10D, K5
AF-540FGZ
Thordell
Posted 24/10/2009 - 18:43 Link
Hi Stefan, all programmes have in the top right corner a X, a - and the square that you can change the window size from full screen to small. Sorry that I am unable to explain but every window has it in all programmes except, in my case, Lightroom now, although it used to.
Jackie H
Most used glass
Prieni
Posted 24/10/2009 - 18:47 Link
Not using Lightroom, but could it be that you switched into full screen mode. I can do it with the browser and I can do it with Photoshop. In Photoshop I can cycle through the different views by bressing 'f', I could imagine that it is the same in Lightroom...
Prieni
Prieni's PPG page
Malo1961
Posted 24/10/2009 - 18:50 Link
Hi Jackie,
Just press Ctrl+Alt+F or go to: Window-----Screen mode------Normal.
HTH,
Best regards,
Martin.
Anvh
Jackie, I know what you mean now, was a bit lost with what you meant.
It has to do with your screen mode, press F to cycle through them or use the menu.
window>screen mode>normal
ps. great minds think a like as you see
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 24/10/2009 - 18:51
stevejcoe
Posted 24/10/2009 - 18:56 Link
Jackie, as Preni thought you have turned on full screen mode.
If you look towards the bottom left hand corner of the interface you will see two boxes labelled 1 and 2 ( primary and secondary window).
Hover the mouse over the box and right click. you will see a number of options relating to view.
Regards - Steve
Edited by stevejcoe: 24/10/2009 - 18:58
Thordell
Posted 24/10/2009 - 19:00 Link
Thank you back to normal now, I have no idea how I switched it off, may be one of the dogs there feet get everywhere. Many thanks I know if anyone could help it would be the PU members.
Jackie H
Most used glass
