lighting conundrum
Posted 29/06/2010 - 11:50
you could try damping-down the reflectivity of the cherry with some Matting spray before putting it on the plate.
Posted 29/06/2010 - 12:00
Would a CPL help?
Posted 29/06/2010 - 12:12
what would you use as a matting spray ??
I'm using a red filter on one light and to light the green stork using a snoot with out a filter. I am getting close but it's still got a small catch light in it
James
oggy what is cpl
James
oggy what is cpl
My Fluidr
Posted 29/06/2010 - 12:16
A circular polariser.
Posted 29/06/2010 - 12:23
Matting Sprays are these sort of things... I have no idea how generally available they are, probably on ebay etc...
http://www.panavision.co.uk/panastore/default.asp?cid=40&clr=true
commerical food photography involves a huge amount of cheating, although there are now rules on how much is used for packaging shots, which is a bit of a problem for icecream in particular!
Posted 29/06/2010 - 12:53
Try bounced soft diffused light, you will most likely require a few scrims to block off excess light.
Brian.
Brian.
Posted 29/06/2010 - 15:12
Hair spray should work I believe
Posted 29/06/2010 - 22:43
yes bouncing would be worth a try but with the strobe behind a black flagging material.
This should diffuse and not make too big a highlight.
Bluewhistle
Bluewhistle
Proud to be a Pentaxian since 1996:
Cosina C1, Pentax Me Super, Pentax MZ5n, Pentax k10, Pentax K7, Pentax K5ii, Pentax K-S2, Pentax 540 flash,
Sigma 10-20mm, Tamron 17-50mm... MF Tamron 90mm, Pentax 50mm F1.7, Sigma 50mm Macro,
Bowens lights, Yongnuo flash.
Warwickshire
Staying on my theme of summer fruit I would like the photograph two cherries on a black polished granite plate.
The granite I’m going to use for a deep coloured reflection which is fine and easy to use and achieve.
The problem I having is I want to try and capture the cherry without a catch light, all the images I’ve seen the cherry has a very high reflective surface and it tends to burn out.
Anyone wants to try and resolve my lighting conundrum.
James
