Light weight Pentax dslr?
Posted 25/11/2012 - 19:39
Even the K-R and an 18-135 is still pretty light - and versatile.
Posted 25/11/2012 - 22:10
With Li-Ion batteries and SD cards included:
K-r: 598g
K-30: 650g
K200d: 684g
K-5: 740g
glass?
40 XS: 52g
35 2.4: 124g
18-55: 230g
18-135: 405g
As you can see, the lens will make a bigger difference.
I tend to have K-5 and 18-135 and it weighs 1145g all up.
f I want to travel light the K-r and 35 adds up to 722g (650g with a 40 XS if I had one!) and much less bulky - but usually the K-r stays on the shelf.
I invariably take the heavier option because of what it offers photographically. Weight problem I have solved with a good wide camera strap (from the 1980's!). If taking a couple of lenses, either the K side bag or K back pack if its a long hike - in which case I often take a monopod. This last item is a useful walking stick as well as something to rest the camera and lens on. Not getting any younger myself!
K-r: 598g
K-30: 650g
K200d: 684g
K-5: 740g
glass?
40 XS: 52g
35 2.4: 124g
18-55: 230g
18-135: 405g
Posted 27/11/2012 - 20:45
For size, the current Pentax bodies are amongst the smallest around. For example, my K-5 more or less the same size as my old *istDS, which for a "semi-pro" body is quite a feat!
If weight is not much of an issue, go for the K-5, as the build is superb and gives you some piece of mind.
As Ronnie has said, the big weight part of a camera kit is the lenses. Fortunately Pentax also excel at this too. Small sharp primes to put on the front of the camera, or some smallish zooms that are quite light, such as the DA16-45mm. My favourite, the DA50-135mm is pretty heavy, but when you compare to rivals lenses, it it a fast sharp lens that is a lot smaller than other makes.
I hope this helps.
I hope this helps.
Some Cameras
Chesterfield
PPG link
Flickr link
