Light meters - vintage or modern?
saxon
Posted 14/04/2014 - 02:35 Link
I'm just moving into studio flash photography and have bought an ILux RD300 system and as a result am on the lookout for a light meter. The Sekonic R308 is the obvious choice at £120 but I'm also tempted by some of the vintage secondhand lightmeters on ebay - Western Master etc.
I would be grateful for any views on whether the analogue meters are any good for flash photography or whether I'm better just going for a modern meter (the vintage ones are only £20 ish)
Thanks,
Saxon
Posted 14/04/2014 - 07:59 Link
Flash exposures are very short, so meters like a Weston Master won't respond quickly enough to register the light.
You need a flashmeter rather than a lightmeter, in other words something fairly modern at least that can record the very brief flash of light.
You can also manage without one as the exposure won't change much for any given lighting scheme and the camera histogram will show you all you need to know. Start at f/8 and alter the aperture until images are correctly exposed. It takes maybe two or three shots to establish the required exposure.
Mannesty
Posted 14/04/2014 - 08:49 Link
Definitely modern. As John has said, you'll need an electronic flash meter. Have a look at the Sekonic range. Some can even wirelessly trigger compatible flash systems to make the taking of readings much easier.
stub
Posted 14/04/2014 - 09:35 Link
Definitely electronic. If your very serious about your studio work. the Sekonic L308s is a good meter. (I have one..) But in my opinion the L478DR is a better choice. Though more expensive. It will trigger the lights from the meter. Give flash / ambient percentage readings.
Stuart..
Chrism8
Posted 14/04/2014 - 10:05 Link
Second vote for the L308s, to trigger the lights I just have the transmitter trigger in my hand and do it manually.
Chris
gartmore
Posted 14/04/2014 - 10:19 Link
Dont even think about a Weston. They were only popular because there wasn't much choice. Rubbish when new and still so.
You could search for a s/h Minolta Flash IV
saxon
Posted 18/04/2014 - 10:10 Link
Thanks guys - Sekonic L308S is now winging its way to me for delivery on Saturday.
Saxon
