Light meter
python118
Posted 17/12/2013 - 21:18 Link
Hi, how many of us use light metres i use my strobes and allways guessing by looking at the LCD screen to see if it looks ok
Regards Dave
pentaxian450
Posted 17/12/2013 - 21:21 Link
python118 wrote:
light metres
Light metres are completely useless with flashes. On the other hand, I love my flashmetre.
doingthebobs
Posted 17/12/2013 - 22:17 Link
pentaxian450 wrote:
python118 wrote:
light metres
My Lunasix F lightmeter does flash as well!
Bob
pentaxian450
Posted 18/12/2013 - 00:35 Link
Mannesty
Posted 18/12/2013 - 07:43 Link
Sekonic L358 for me. I rarely use it for outside daylight work, but always indoors with flash.
Chrism8
Posted 18/12/2013 - 09:22 Link
Exactly the same
Chris
Edited by Chrism8: 18/12/2013 - 09:22
gartmore
Posted 18/12/2013 - 10:14 Link
Since I know my lighting kit I find I rarely use a meter much at all but would if I needed to calculate lighting ratios
Class_A
Posted 19/12/2013 - 04:27 Link
Measuring lighting ratios is the only good application I can see for a lightmeter these days.
One can judge exposure using the histogram on the back LCD and from what I have seen how people use lightmeters, their process is not really quicker or less demanding on strobes.
I find that the visual feedback is good enough for judging lighting ratios and if you really wanted to be more systematic, you could also calculate lighting ratios by considering the strength and distance of light sources.
So in summary, I don't feel that there is much room left for external lightmeters in the digital age.
Edited by Class_A: 19/12/2013 - 04:28
RalphHardwick
Posted 19/12/2013 - 08:21 Link
Exactly the same
+1 more
CaptureLight Ltd
flickr
stub
Posted 19/12/2013 - 17:09 Link
When setting up studio lights. I wouldn't be without my sekonic 308s. Im looking to upgrade to the 478 at some point. They are that good....
Stuart..
Edited by stub: 19/12/2013 - 17:09
Algernon
Posted 19/12/2013 - 18:27 Link
That looks a very messy meter to use
http://www.youtube.com/watch?v=5dKNAzkeiWA
I've had two Sekonics just die in the past. The Gossen Digipro F's
(or similar) are much better. Faster than using the camera to take
a reading. Aperture priority and shutter priority. I've two of them.
Handy that they use a cheap single AA battery.
The contrast range reading at the end of the video is great for
incident light readings say by a window. It shows you the full range
of stops covered.
http://www.youtube.com/watch?v=0q1s1zCQ6z0
Flash meters are useful with manual flashes to see if the
power settings 1/2... 1/4... 1/8 etc. are correct or not.....
they rarely are
python118
Posted 20/12/2013 - 12:19 Link
The L 308s is one of the low cost lightmetres with good reviews and to be fair it does the job. I value my photography but don't know wheather I want to spend two or three hundred pounds or more on a lightmetre.
Regards Dave
Chrism8
Posted 20/12/2013 - 14:56 Link
Hi Dave, as prev stated, I use a L308s on my lighting setups, you can do it by the histogram, but it is easier with a meter and more professional imo.
I tend to use a 4 light setup with a white BG and 2 lights with a black BG, and prefer to set the lights 1.5 stops higher on the BG than the main and set the fill to 33% - 60% of the main.
This takes less than 5 minutes and would be tricky as either guesswork or to do via the histogram.
A new L308s is around £130 these days and you may be able to pick up a prev owned one on fleabay for less.
Chris
python118
Posted 20/12/2013 - 16:35 Link
Cheers Chris will get one after xmas have seen them for £107 new, a bit fed up with looking on back of camera don't think you can allways trust histogram, have a good Christmas all
Regards Dave
Don
Posted 20/12/2013 - 19:07 Link
I still use my polaris flash meter a lot.
especially when shooting video, and setting up lights.
