Lenses with Aperture rings
Selecting the aperture via the camera should give exactly the same result as using the ring. I think there may be something funny about your Vivitar if you get different effects with that with the different methods. And the Sigma being too dark is probably nothing to do with the lack of aperture ring. The camera just does expose differently with different lenses sometimes. Compensation is required then.
Welcome to the best forum in the world!
(But you already knew that didn't you?)
Just a thought but are you using the newer Sigma with the teleconvertor? If there's no aperture ring on the lens, and the camera can't talk to the lens because the T/C is inbetween them, then the lens will be stuck at its smallest aperture at all times (normally f22 or f32 or thereabouts) which would account for severely underexposed images.
I guess I may be better off with an older 2nd hand lens
DA 55-300
DA 16-45
DAL 50 1.8
Pentax Optio compact
Pentax ME Super 35mm SLR
Another alternative would be an auto converter - auto-exposure or even auto-exposure and auto-focus. The fully auto Kenko 1.5X I have works reasonably well with the Tamron 70-300.
Yes the teleconverter is manual - 1980s vintage from when I bought my original ME super
I have a 7 element teleplus auto converter which cost me about £30 on fleabay, they aren't necessarily expensive.
but it does help
Many thanks for all the replies.
DA 55-300
DA 16-45
DAL 50 1.8
Dunstable,
Beds
However when I try and use a newer sigma 55-200 lens which does not have an aperture ring. The results are much too dark.
I would like to upgrade to 70-300 mm lens and use the teleconverter as funds wont stretch to sigma 50-500.
Any solutions would be welcome
DA 55-300
DA 16-45
DAL 50 1.8
