Lens stuck on camera body
Posted 13/01/2008 - 01:35
think we should rub it in about the little trick that involves snapping the lens release button while turning the lens to jar the pin loose from the af screw with out actuallt damaging anything?
Posted 15/01/2008 - 02:19
Thats an absolute cracker of a story and i do believe he was actually enjoying himself
Don: your idea seems to make a lot of sense and appears obvious to me. So you just break off the lens release button and remove the spring holding the pin into the AF screw hole and wriggle it somewhat until the pin drops out. Is that your meaning :
Camera:|K-7|
Posted 15/01/2008 - 02:23
nope, just press the button down, and slide your finger off the button, allowing it to "snap" back.
Posted 15/01/2008 - 02:49
Of course, the way i explained it would mean damaging the camera How dumb nope, just press the button down, and slide your finger off the button, allowing it to "snap" back.
On the subject of dumb things you are all invited to my place for a BBQ and a swim
Don you will have to keep your parka on as i am having recurring nightmares about your nipples
Camera:|K-7|
Posted 15/01/2008 - 04:08
It looks to me like your skating rink has defrosted...how do you keep your beer cold down there? Who's your electrician? Dr Kervorkian?
Posted 15/01/2008 - 08:07
I hadn't realised that mains electricity was 12v DC in Australia
Posted 15/01/2008 - 11:20
snip . . . On the subject of dumb things you are all invited to my place for a BBQ and a swim . . . snip
Contendants for the Darwin Awards by the looks of it snip . . . On the subject of dumb things you are all invited to my place for a BBQ and a swim . . . snip
Posted 17/01/2008 - 11:33
What you can't see from this picture is that the man on the left has smoke coming out of the top of his head.
~Pete
Posted 17/01/2008 - 12:31
Many years ago I witnessed a trainee electrician ask "Is this (3 phase supply - 440 volts 100 amp) live?". His supervisor replied " I don't know, cut through it and see".
The trainee did what he was advised and cut through all 4 wires. He was on a step ladder at the time. The resulting explosion threw him off of the step ladder, welded his cutters together, and shut the factory down for 2 hours whilst the damage was repaired.
The moral: To trust is good, to check is better.
Posted 17/01/2008 - 21:08
That guys supervisor sure has some extreme and dangerous teaching techniques Many years ago I witnessed a trainee electrician ask "Is this (3 phase supply - 440 volts 100 amp) live?". His supervisor replied " I don't know, cut through it and see".
The picture i posted was a contrived shot We aussies are tough not dumb. Or is that the other way around hmmmm
Camera:|K-7|
Posted 15/02/2008 - 02:02
Back to that Albinar lens that was stuck, you can generally get them off by carefully sliding the .005mm blade of a filler gauge between the lens and body near the AF drive while wiggling gently and holding the lens release button at the same time (it also helps to have a friend to help). I released a few like that.
21 years
Totana,
Spain.
