Lens range expanding??
Posted 14/12/2006 - 10:38
There is a lens roadmap in PDF format on their main website. http://www.digital.pentax.co.jp/en/lens/roadmap.pdf
Current lenses listed here http://www.digital.pentax.co.jp/en/lens/
Of course you can use all their existing lenses back to and including M42, and the Samsung lenses should work. However there is plenty of coice in the Pentax line alone, thought Sigma and others do make some good lenses too.
Posted 14/12/2006 - 10:53
as far as I know all the currently available Samsung lenses are re-badged Pentax lenses which may or may not have SMC coatings, so while they will work fine I wouldn't bother too much about them unless they are significantly cheaper.
Posted 14/12/2006 - 12:23
Hi Downswood,
Are there lenses in particular that you'd like to see? i.e. what do you feel you're missing with Pentax that you'd consider changing systems for?
I've got a full range of focal lengths from 10mm through to 300mm, mostly Pentax, some Sigma, one Tamron. I don't see the lens choice as a problem at all, but obviously it depends on what you want. Admittedly, large aperture, long focal length lenses are harder to come by, but they are made by independents if you want to buy new or secondhand (I've got a Tamron 300/2.8 ), and Pentax ones can be found secondhand (and probably new if you hunt for them, someone else here would be able to advise you on that).
Also, the Pentax 10-17mm fisheye zoom is unique, and is the envy of many other system users, to the extent that I saw one Canon user say they'd buy the K100D just so they could use this lens.
Let us know what you feel is lacking, and we'll try to advise the best remedy. Several on here have in depth knowledge of the lens range, and as there is 40 years worth to choose from, there's bound to be something to fit.
Dan
Dan
Posted 14/12/2006 - 12:37
its amazing how many canon users are ignorant of what I consider to be the only major benefit of their system of choice. The back focus distance is so short they can mount almost litterally anything using a suitable adaptor.
Posted 14/12/2006 - 14:08
But as the lens has no aperture ring they'd have no way to control the aperture - so they'd be shooting at f/22-32 all the time, not ideal...
Better to buy Pentax in the first place.
Dan
Dan
Posted 14/12/2006 - 15:16
ahhh, good point, I'd forgotten that!
/me bangs head against something
Posted 14/12/2006 - 16:50
Why doesn't someone make an adapter with an aperture ring? Or am I being stupid?
Posted 14/12/2006 - 17:09
Whose side are you on? We need to make them buy Pentax, to see the error of their ways! Why doesn't someone make an adapter with an aperture ring?
But anyway, I suppose you could make an adaptor that would move the 'aperture activation lever'* to the required position to close the aperture down to the required size. Probably have to be geared somehow, otherwise it would need a very small turn of the ring to go from min to max. Also, not sure that all lenses would have exactly the same lever design, so variations in exposure might occur between lenses. Also, might have problems with lenses of differing maximum aperture.
Apart from that, should be a doddle. Weekend's coming up, get the cornflakes packet and sticky-back-plastic at the ready!
Dan
* Probably a proper name for it, but you know, the wobbly bit that makes the aperture close down.
Posted 14/12/2006 - 17:11
I'd buy one.
Peter, I do hope you haven't got a Canon upon which you wish to fit your Pentax lenses. Or did you mean to get an aperture (apparature) ring on DA lenses to use on your Pentax's?I'd buy one.
What is the plural of Pentax? Pentaxes? Pentax's?
Dan
Posted 14/12/2006 - 17:43
Some Pentax lenses can be fitted without adpators on Canon
The 11-17 and 12-24 I believe can be fitted on Canon....but you'd get it in a box saying Tokina and without the special Pentax coating....
But then you'd lose out by fixing such an inflexible body on the lens
Posted 14/12/2006 - 17:59
Dan
it wouldn't work on a pentax, theres no space, unless you put some sort of optics in the adaptor which would of course have quality implications. It might be possible on a Canon if the back focus on Canons is short enough to allow a decent sized aperture ring to go in between lens and body without sacrificing infinity focus.
Mannesty wrote:
I'd buy one.
Dan
Posted 14/12/2006 - 20:23
IU'd just like to emphasise, for the copyright lawyers benefit, that it was my idea, and all royalty cheques should be made out to me!
Posted 17/12/2006 - 21:33
Thanks for all the comments. I'm on a strict budget and they do seem relatively expensive. I may have to compromise and end up with some Sigma lenses. For instance I'd save a lot if I got a sigma 105mm maco lens. The don't do the 70mm for Pentax. This is my next port of call.
The road map was helpful but some are a long way off like a fast 300mm which is what I'd like for birds but I may never be able to afford that.
21 years
Durham
I'd like to get the best I can but I'm at the stage now where I may change brands if I upgrade. Should I really be bothered by this or should I include the Samsung ones in my calculations if they are compatible.
Any advice for a waverer.....LOL
