lens or flash? please advise
Posted 05/06/2009 - 13:16
Generally speaking, slowing your shutter will not increase a flash exposure. Increasing the aperture and ISO will. How far away were you from the dancers? Can you post a photo?
It basically sounds like the flash isn't powerful enough for your needs.
Posted 05/06/2009 - 13:20
My experience with the built-in flash of the K10D is that it is about as powerful as a spent match. I'd invest in an external flash and Mattmatic's flash "ebook". I tend to set my camera on manual when using flash as I find the fancy in-built flash modes more of a pain and less reliable than a bit of trial and error.
The main problem with using flash outdoors is there is nothing to bounce it off, and direct flash is unflattering.
Best wishes, Kris.
Best wishes, Kris.
Posted 05/06/2009 - 15:16
You may be able to pick up a cheap old powerful flash gun as I did from a charity shop for a fiver. Then invest in the radio trigger device from the shop on this site for 16 quid and you have an off camera flash for 21 quid which can't be bad.
Spend a bit more and get a Vivitar 283/285 and that's decently powerful but you must be very careful about mounting them on the camera hot shoe as they may well blow the circuits in the camera. Hence the radio trigger.
Posted 05/06/2009 - 15:23
You're saying Morris dancers, I don't find a bit of blur movement a problem with that. You can even go to extremes with that. they surely shouldn't be pin-sharp, it will kill all movement. At least that's my view on the matter.
The 28mm 2.8 isn't expensive secondhand so you can give that a try and also get a flash. It's best in your case to have one with some creative options like trailcurtain and maybe even strobe. If I need to chose it would be the flash... atleast if you can use inderect flash... My experience with direct isn't so great, it will kill depth so you might need some accessories to help in that. Kris also say it's unflattering.
Posted 06/06/2009 - 15:18
Thanks to all you kind people for taking the trouble to help,it is appreciated.
As for distance(greynolds999)aprx 3mts to 20/25mts.
Anvh suggests 28mmf2.8,is this preferable to 28.. f1.8?
Regards to all, Larry.
Best Regards, Larry.
All the gear & no idea.
Posted 06/06/2009 - 15:21
Best wishes, Kris.
Dear kris,My experience with the built-in flash of the K10D is that it is about as powerful as a spent match. I'd invest in an external flash and Mattmatic's flash "ebook". I tend to set my camera on manual when using flash as I find the fancy in-built flash modes more of a pain and less reliable than a bit of trial and error.
Best wishes, Kris.
Please explain 'Mattmatic's flash "ebook" '
Thank's Pal.
Posted 06/06/2009 - 17:15
Sorry I thought you wrote f/2.8 Anvh suggests 28mmf2.8,is this preferable to 28.. f1.8?
But I don't believe there is a f/1.8 at least not a Pentax one.
Ware,Hertfordshire
Question; Do I need a faster lens (f1.8,28mm?)If so, can you reccomend? or do I need to get a good flash? again, any suggestions which? Or a combination? Or is it just me needing more experience?
Thank's in advance for any help you may think useful(apart from swapping my camera for golf clubs)
