Lens not functioning in manual mode
Posted 29/10/2022 - 10:58
Posted 29/10/2022 - 11:31
It looks like you might be right about the spring.
All the gear with no idea
Posted 29/10/2022 - 12:00
In Denmark wages are to high for sending a lens like this for repair. Cheaper to buy a new.
Have anybody tried themselves to disassemble a lens? And assemble it again also of course
Posted 29/10/2022 - 15:44 - Helpful Comment
I've done a few of them, complete disassembly to get to elements that had residue on them from fogging up, this is the guide I've followed.
https://www.flickr.com/photos/fluffyrazor/albums/72157630944498102/
I think in your case, you'll not even have to take the metal mount off (avoid this since the contacts are spring loaded and a devil to put back), just the inner plastic cover which is held in place with one or two screws from the side.
With that cover removed, you should be able to see if the spring has simply come unhooked (see the third image on that link).
Hope that helps.
Hope that helps.
Posted 29/10/2022 - 15:56
Posted 29/10/2022 - 16:06
Be careful not to damage the screw heads. Japanese Industry Standard (JIS) cross-head screws are slightly different to Phillips cross-head. I've just bought a set of JIS screwdrivers in order to remove a mount (from an extension tube) and it has made it easier to remove screws without fear of damage. They were fairly cheap from a UK importer at the usual auction site, not sure about availability elsewhere in Europe.
Posted 29/10/2022 - 16:07
Yep, those ones, the back plastic cover will then lift out, it's got like a inner collar on it.
It can only go back on one way because of the window for the aperture lever.
Posted 29/10/2022 - 16:20
The sixth picture on that link above, shows you the inside of the metal mount and how the plastic cover is fixed, looks like 3 screws.
Posted 29/10/2022 - 16:58
Thanks - I think I will try with whatever small screwdriver I have. Buying a JIS screwdriver set will cost more than half of what I can buy a secondhand unused similar lens for not far from where I live.
And I am not sure I can fix the one I have.....
Posted 29/10/2022 - 17:12
Just realized that by zooming fully in I can actually see the spring being in place as it should be
Some something else must be bent or something like that. Had it been some other sort of mechanics I may have tried some oil....
Now I think I will go for buying the secondhand unused lens as price is just Dkr 500 (67€ or $).
Perhaps I can negotiate price a little
Posted 31/10/2022 - 08:27
A decent set of JIS screwdrivers should last a lifetime so it may be a decent investment.
Shooting in P mode does not reveal any problems but I fear lens aperture is actually "frozen" at wide open.
Shooting in Av mode suggest this is right as images get overexposed when setting aperture to anything else than full open (smallest f value).
Have tried on both my K-3 and my K 200 and problem is on both cameras.
I have tried cleaning the lens contacts with paper tissue but no luck.
Years ago I changed from the K 200 to a K-3 because I thought I had damaged the K 200 when dropping it (with the actual lens on) - it sometimes gave way off exposures. Truth is perhaps that I damaged the lens, not the camera.....
