lens for portrait
Posted 01/08/2010 - 14:54
I have Tamron 17-50. It's excellent, except often needs an AF adjustment, so I only recommend it for the K20D and K-7 cameras as they allow AF adjustment for individual lenses.
16-45mm is a bit short for portraits. I think you would be happiest with a Sigma or Pentax 17-70mm.
You could have a prime in addition if affordable. One wouldn't take up much room.
~Pete
Posted 01/08/2010 - 15:01
thanks pete. i did look at the pentax 17-70mm but it is to pricey,
also looked at a number of reviews and the sigys come out about the same and the tamron always seems to do a tad better.
i will be using a k7.
any body with any pics taken ith the lenses fancys posting them feel free.
Posted 01/08/2010 - 15:58
I agree with Stefan, the Tamron 28-75 (set at 75mm) would be the better for portraits and the constant F2.8 is a nice touch. When converted 75mm would come close to 109mm which in MHO would be the prime for 135 film use. I have a Tamron 28-75 and use it constantly, it is probably my most used lens. I highly recommend it. Over here they tend to be a bit pricey when new, but you should be able to find a good used one at reasonable cost.
Good luck,
Stephen
Good luck,
Stephen
I gladly welcome C & C's. Being foggy minded they really help me learn.
Posted 01/08/2010 - 23:06
You should instead consider an A 50/1.7, which might set you back 40 sterling. This would give you an excellent field of view for portrait work and much more depth of field control.
im looking at the Pentax SMC DA 16-45mm F4 Lens,
also the Sigma 17-70mm F2.8-4 DC Macro OS HSM Lens,
also the Sigma 18-50mm F2.8 EX DC Macro Lens.
and the Tamron SP 17-50mm f/2.8 XR Di II LD,
my budget is no more than £350,
any one has one of these an can comment on quality i would be most greatfull.
If anyone knows of any other lenses i should look at,
im not interested in primes at the moment,
as im tight for room and need a flexible lens.
Thanks in advance.
