Lens fitting for Pentax MZ-50
Lynne
Posted 01/02/2004 - 09:59 Link
Hi
I have a Pentax MZ-50 camera for which I'd like to buy a fast lens, preferably a zoom. However whenever I try to find one I come up against several different 'fit' descriptions - FA, AF, KAF, Z etc.
Does anyone here know the definitive fitting for this camera? I almost bought a second-hand one from ebay before I was informed that the auto focus and programs wouldn't work with it.
I've tried to find one or other of the lenses mentioned in the handbook I got with the lenses when I bought my camera but the shops I've been in don't seem to recognise those model numbers!
If anyone out there has an MZ-50 or is familiar with it, could you tell me what fitting I need to search for to be sure I get a lens I can use on the auto settings on the camera?
George Lazarette
Posted 01/02/2004 - 12:26 Link
Unfortunately you have one of the "crippled" mount cameras, which will not allow you to use early K-mount lenses - those called "K" or "M".
To cut a long story short, you must uses lenses which have an "A" setting on the aperture ring, next to the smallest aperture, normally f22.
Any Pentax lens called "A" or "FA" or "FAJ" will work, as will most non-Pentax lenses (with a K bayonet mount) with the "A" setting on the aperture ring.
For more information, read the "Bible":
http://www.bdimitrov.de/kmp/
George Lazarette
Posted 01/02/2004 - 12:42 Link
I should have added that the "A" lenses are manual focus only, but otherwise work fine with your camera.
Manual focus is not a major disadvantage, especially on a fast lens (which lets in a lot of light when you are focussing).
As a generalisation, fast zoom lenses are either very expensive or not very good.
Just about the fastest lens you can buy for the camera at reasonable cost is also the best and amongst the least expensive. It is the 50mm 1:1.7 Pentax-A. Manual focus, but one of the finest lenses ever made for any camera at any price. The FA version (autofocus) is optically the same, but much harder to find. The 1.4 version is also superb, but much more expensive.
Have a look here for information: http://www.bdimitrov.de/kmp/
And here for lens recommendations: http://stans-photography.info/
Buy one of the photographic magazines to get a rough idea of price differentials, then buy on Ebay (with care!).
Lynne
Posted 02/02/2004 - 14:47 Link
Thank you George, most helpful. The 50mm you mention is one I've had my eye on for a while and also a Sigma :- 28-105mm f2.8/4 ASPHERICAL PENTAX AF. I know that you get what you pay for but any opinions on whether or not it's worth bothering with? All I'm after is a little higher ratio of pics that come out to pics that don't, taken on 3200 b&w at music concerts. I'm no professional and all I want is mementoes.
George Lazarette
Posted 02/02/2004 - 20:08 Link
I've assumed, from the fact that you are using a fairly inexpensive camera, that cost is a consideration.
When it comes to zooms, my opinion (others may well differ, I am increasingly anti-zoom!) is that the smaller the zoom ratio (40-80 would be 1:2, 80-320 would be 1:4) the fewer the compromises that have to be made, and therefore the better the end-result.
Bear in mind, that although a lens may offer a nominal fastest aperture of say f2.8, it does mean that it will be any good at that aperture. Nearly all lenses are at their worst wide-open.
An f4 lens which performs reasonably well wide-open is a better bet than an f2.8 lens which is lousy wide open.
However, such problems may not be very noticeable with the kind of subjects you shoot. Since the lighting (I assume) is likely to be highly unnatural, viewers might well accept imperfections which would not be acceptable in a picture of a building.
My advice would be to analyse what is going wrong with your worst shots, and also try to decide what facilities are absolutely essential for you, and what focal length(s) you mainly shoot at (or would like to). You may find that you could buy a couple of inexpensive fast prime lenses and that they would do a better job for you than a slower, less sharp, zoom.
Good luck
Anonymous
Posted 03/02/2004 - 09:19 Link
Excellent advice George, IMHO absolutely spot on
Kimbo
Posted 03/02/2004 - 09:21 Link
err - that was me BTW, forgot to log in
Lynne
Posted 03/02/2004 - 12:22 Link
Cheers folks
