Lens and lens mounts
annieogg
Posted 13/05/2012 - 10:51 Link
I knew that older lens would be useable on the K-5 so bought a SMC PENTAX- M 1:1.7 and Vivitar 28-70 1:3.5 - 4.8 MC. I'm happy enough with them got them to force me to use manual settings. Looking on here I have seen that M42 screw mount lens can be used on newer cameras but was wondering if the were adapters for other lens mounts. My first DSLR was an Olympus E510 which I still have along with a 70- 300mm lens which seemed better than the Tamron on I have and wondered if there was an adapter that could do this? I realise that the for thirds crop might make a difference as on the Olympus the zoom appears much longer. I intend to keep the lens and camera perhaps to have set up on bird table permanently. Being able to use with the K5 would be a bonus.
All roads roam to Leeds
linklink
Pentax K-5 18-55mm Tamron 70-300mm
Pentax 35mm
a few filters Manfrotto tripod and monopod Silk tripod and a bumbling approach on how to use them
Frogherder
Posted 14/05/2012 - 16:21 - Helpful Comment Link
Try the following :-
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=m42+to+...
http://www.ebay.co.uk/sch/i.html?_nkw=m42+to+olympus&_sacat=0&_odkw=m42+to+pk&_o...
Can't comment on using M42 lenses on your Olympus but they work well on the K5 (make sure you pick the flangeless version to ensure focus on infinity, unless you intend using it over a reduced range)
Further thought - I removed the small spring which locks the adapter into place otherwise its a 'pig' to remove, but this does mean that the lens might - might fall out.
regards
Bernard
annieogg
Posted 14/05/2012 - 18:07 Link
Thanks Bernard I'm going get the one for pentax mount defiantly.
I had seen the M42 to Oly adapter when i was searching before which would be useful as I could use screw mounts with both cameras.
This may now seem a daft question. Does that mean if I put a M42 on the oly lens I could the use the pentax to M42 and the Oly lens would would fit on that.
I'll remember about the flange and the spring thanks for the advice. But I have a feeling my Oly Lens will have to just stay with the Oly. The other option is to sell the Oly lens towards buying something my K5 can use
linklink
Pentax 35mm
Posted 14/05/2012 - 18:22 - Helpful Comment Link
If you want to look into adapters, then SRB-Griturn have the knowledge to tell you what is and what isn't possible.
jonrob
Posted 18/05/2012 - 10:59 Link
I am interested in a fast lens for sports and some indoors. I have been recommended to DA*50-135 but reviews I read are some years old. Please is this lens still available and will it be fully functional on my
Pentax K200
jonrob
Posted 18/05/2012 - 11:07 Link
The lens is still available and will be fully functional on your K200.
Frogherder
Posted 18/05/2012 - 20:09 Link
[quote][This may now seem a daft question. Does that mean if I put a M42 on the oly lens I could the use the pentax to M42 and the Oly lens would would fit on that./quote]
The 'only' ones I've seen are M42 (female - ie the M42 lens screw into the adapter) to xx(male - this then fits the camera) where xx is the mount required by your camera (K for Pentax, OL for Olympus etc)
So I can't see how you'd get from OL - M42 - K. But with two appropriate mounts you could use the same lens on a range of cameras
regards
Bernard
Posted 18/05/2012 - 23:59 Link
It's a complex issue that depends not only on fitting the lens, but also on the back-focus distance to the sensor. Not all lenses can be fitted to all cameras. When they can, sometimes they don't focus to infinity and sometimes they are not easy to use.
SRB-Griturn are the experts on what is possible and what is not.
petrochemist
Posted 19/05/2012 - 09:13 Link
The rear focus distance for OM lenses is 46mm, (about 1/2mm more than the PK mount) so if the mount fits inside the PK body an adapter would be possible, I do't think it does - but I've never tried.
For macro work you can get adapters to allow the use of just about any lens on any SLR (with a bellows in between). Some bellows systems have adapters to directly couple the lens mount & camera mount, giving a lens/camera adapter with less extension but even with this sort of connection maximum focus distance will of course be relatively short in most cases.
Freelensing is also a possibility for incompatible camera/lens mounts but runs the risk of dust on your sensor and is often only possible for close up/macro work.
There are also adapters made for some camera lens combinations that include an optical element to extend the back focus distance, getting round the infinity focus issues - This will degrade the image quality somewhat. It might be possible to rig something similar yourself by modifying a teleconverter, using the OM mount from a set of cheap extension tubes for example.
Of course there are also T2 & adaptall lenses which are designed to work with adapters to mount on just about any SLR.
It might be possible to get the lens converted to a M42 or T2 mount allowing it to be used with appropriate camera adapters on either camera.
Unless your OM lens was really stunning I suspect any adaptation will cost far more than it will be worth. There are loads of affordable PK zooms covering this focal range many of which are optically quite good. (My sigma 70-210 proved somewhat of a dog though)
Edited by petrochemist: 19/05/2012 - 09:17
Algernon
Posted 19/05/2012 - 09:36 Link
The OM mount can be made to lock onto the PK mount with
a little bit of Dremel work on the OM mount. It can
also be swapped for a PK mount.
