Kr and remote shutter control
downswood
Posted 27/06/2011 - 23:33 Link
I recently bought a Kr to upgrade from my ds. Very nice but disappointed to find no jack socket for a remote. I want to shoot long night exposures but the manual says shutter open as long as button pressed but I don't want to hang on to the camera for 5 mins. Is there another remote that I can use which will do this for me, an IR one perhaps
thanks in anticipation
Gerry B
geclinke
Posted 28/06/2011 - 00:55 Link
On the k5, when in bulb mode you can select that first remote click opens the shutter, second closes it. You might be able do the same on a kr, you'd need to check the manual.
k5, 50mm FA, 18-55mm Kit, 50-200mm DA, 15mm Fisheye Sigma, 10-17mm DA Fisheye, 18-55mm DA WR, DA* 60-250, DA* 16-50
geordie01
Posted 28/06/2011 - 06:43 Link
[quote:3496ace15f="geclinke"]On the k5, when in bulb mode you can select that first remote click opens the shutter, second closes it. You might be able do the same on a kr, you'd need to check the manual.[/quote
yes it is the same with the k-r
downswood
Posted 29/06/2011 - 00:17 Link
thanks for that. It has pointed me in the right direction. i'll check with a Pentax store to see the best thing to buy.
Thanks again.
