Keep it warm
Digital SLRs will be OK down to 0C, maybe a little lower. The new K7 is rated to operate down to -10C.
You could try keeping the camera tucked inside your coat until ready to take a picture. As batteries may be your problem, keep the batteries in a warm pocket and put them in the camera just before use. Batteries do not work as well in extremes of cold, so also use freshly charged ones.
but it does help
Tobio
K20d with Tamron AF 90mm f/2.8 Di SP macro , smc da 18-55 mm, smc da 50-200 mm and smc da 55-300 mm + Metz 58 af-1. Editing with Pentax Photolab, Gimp and Paint.net.
Steven
Batteries are the major problem, recharge them fully and if you've two keep one in your inside pockets of your jacket to keep it warm.
When one battery fails swap it for the warm one and then warm it up in turn. When it gets back up to temperature it will work again.
Buffalo,
Wyoming USA
Steven
