Kayak slalom (3 shots)
CoDa
Posted 03/07/2010 - 21:01 Link
These are the first shots taken with the 120-400mm Sigma HSM lens that I recently purchased.
Cropped with a bit of colour adjustment only, K10 on a monopod.
The Venue
[IMG]http://i941.photobucket.com/albums/ad254/weldingblues/Photos%20for%20comments%202010/TheVenueresized.jpg[/IMG]
No 47
[IMG]http://i941.photobucket.com/albums/ad254/weldingblues/Photos%20for%20comments%202010/3Kayakresized.jpg[/IMG]
No 78
[IMG]http://i941.photobucket.com/albums/ad254/weldingblues/Photos%20for%20comments%202010/4Kayakresized.jpg[/IMG]
C & C to assist please
Colin
Edmund Burke (1729 – 1797)
bwlchmawr
Posted 03/07/2010 - 21:13 Link
Two's good, Colin, but three's even better. Expression and water droplets!
Best wishes,
Robert Adams
Ernst Hass
i-Berg
Posted 05/07/2010 - 10:59 Link
Col,
Looking at your EXIF data, shots 2 & 3 are from the lower end of the zoom range (120 and 230 mm). What's it like at the long end?
There are two things that I believe I can see in Nos 2 & 3 - they might both be a little back-focussed, with the result that the subjects are not quite as sharp as you'd like.
Second, your vantage points meant that both their faces are in shade and you're shooting into the sun. That makes your job harder than it could be.
No 1 is a bit busy for me, and doesn't have an identifiable subject, nor light that is particularly flattering for the scene.
I'm interested in your thoughts on shooting with a fairly long lens like this, using a mono-pod. First impressions?
thoughton
Posted 05/07/2010 - 12:02 Link
3 had the most potential for me, but the missed focus is unfortunate. The embankment behind her seems quite a bit sharper than she is. I can empathize though, I am constantly having similar problems with my newish 70-200! Still haven't quite cracked it yet
Tim
CoDa
Posted 05/07/2010 - 14:46 Link
Thanks Andrew.
i-Berg, I have not tried it at the long end yet, hopefully this weekend. The positions for shots are really limited and they did not start the races until 1:30 so sun etc is a nuisance. What is "back-focused" I have seen it mentioned but until now did not think to look it up or ask. The combination using a mono-pod seems to work OK, I did leave the SR on as well.
Tim, thanks for the comment, there is another race meeting in the same area in September two weekends with a weekend between, so hopefully I can try again then.
Regards to all
Colin
CoDa
Posted 05/07/2010 - 21:52 Link
i-Berg, I checked the EXIF data using PhotoME, it has correctly identified the lens as the "Sigma APO 120-400mm F4.5-5.6 DG OS HSM" the OS is not fitted to my lens.
The focus point as far as I can tell was on the 7 of the vest. I was using Fixed centre focusing, SR on with the SR focal length showing as 230mm.
Lens focal length showing as 230mm as well.
All the camera settings are normal i.e. I have not adjusted anything.
Colin
CoDa
Posted 05/07/2010 - 23:05 Link
I have posted the No78 again this is with only auto colour adjustment, is it sharper on the person? or the same?
No 78 - only auto colour adjustment
[IMG]http://i941.photobucket.com/albums/ad254/weldingblues/Photos%20for%20comments%202010/Kayak4resized.jpg[/IMG]
C & C to help please
Colin
i-Berg
Posted 06/07/2010 - 10:14 Link
Col, the lack of sharpness might just be less obvious by being partly hidden in the shadows.
The back wall of the canal is still sharper than the paddler, so the camera may have latched on to something behind your intended subject(assuming it was autofocus?), when the shot was taken.
