K7 movie mode max time
bigkuri
Posted 14/11/2009 - 21:31 Link
Hi All,
I'd usually just read the K7 manual for this question, but I'm travelling in the States without it, and don't want to download a large PDF over a 3G (UK) mobile! Ouch $$££$£...
On this trip I have started to use the movie mode a lot more, and have noticed that when I start recording it shows how many minutes I can take to fill the SD cards capacity. But after about 30 to 40 seconds the recording stops and this is effectively the max movie length I can take. On 16:9 mode. The allowed length/size does not seem consistant - 164MB to 230MB.
User error? Limit of the camera? Or the SD card? (currently a 8GB Panasonic Gold Class 10)
Many thanks for any answers, and apologies if I am delayed in responding due to travel.
Rick
Edited by bigkuri: 14/11/2009 - 21:32
Anvh
Posted 14/11/2009 - 22:17 Link
Strange... the file limit is 4GB because of the FAT format used.
Format the card with the camera and try it again.
Other then that it's probably an user error, a setting that you've changed in your menu for example. I don't have a K-7 so can't help you with that but if it becomes urgent you can reset your settings to manufacturing default and that would solve it most likely.
Stefan
K10D, K5
AF-540FGZ
Mike-P
Posted 14/11/2009 - 22:44 Link
Have read on another forum a number of times of this happening and it was always down to the memory card used.
iceblinker
Posted 15/11/2009 - 00:12 Link
Live View and Movies stop when the sensor overheats. This may happen in warm weather or just after the camera has been used a lot.
~Pete
bigkuri
Posted 15/11/2009 - 11:33 Link
Thanks guys for the suggestions. I played around with things a bit more during today and solved it with your help.
= SD Cards.
I have 2x8GB Class 6 and 1x8GB Class 10. All limit the movie size.
If I put in any old thing, even a microSD 4GB with an adaptor - movie limit is simply space on the card.
Go figure. What am I missing? I had thought the K7 could handle cards up to 16GB? The 8GB cards certainly are ok with stills - no problem there?
Many thanks for your responses, and that really helps out for this trip - maybe I need to buy new cards on my return.
Rick
Anvh
Posted 15/11/2009 - 12:31 Link
32GB even.
Strange the 8GB card is the problem though, class 10 should be fast enough, I believe class 6 is the minimum speed for video use.
Like said the 4GB limit is the FAT32 format limit.
Hopefully exFAT will be the standard soon for removable data, it has a file size limit of 64 ZB so that should solve the problem for a while
Still it doesn't explain the problem though...
ps. seems the speed is the problem link
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 15/11/2009 - 12:44
bigkuri
Posted 15/11/2009 - 12:45 Link
Thanks for that link Stefan. As all things internet I also found this thread going on at the same time.
link
Just weird about the Panasonic Class 10 - never would have thought speed an issue, but the proof of the pudding!
Back to stills for this trip! And time for bed before wifey kills me, ain't jet lag wonderful...
Thanks again for the help,
Rick
Anvh
Posted 15/11/2009 - 13:10 Link
In my link they said the 720P is memory hungry.
What if you use 1536 x 1024, they said the files is less large and therefore better for slower cards.... strangely enough the resolution is more the 720P though
At home you can probably quite effectively make it in to 1080 HD size by upscaling it, have never tried that though.
Stefan
K10D, K5
AF-540FGZ
pentaxian450
Posted 15/11/2009 - 13:18 Link
Do you have any lens correction enabled?
bigkuri
Posted 16/11/2009 - 07:27 Link
Lens CA - nope. I read it slows down pretty much everything so I've been avoiding any of my glass that would need it...
Completely and utterly the SD Cards to blame here. A pity as I thought the Panasonic would be up for it.
So for the rest of the holiday any movies I am using a 8GB microSD card in an adaptor! Works a treat... (and cost about 1/5th of what the other cards cost)
pentaxian450
Posted 16/11/2009 - 13:59 Link
I use a Panasonic Class6 with absolutely no problems.
Greytop
Posted 16/11/2009 - 14:09 Link
If it helps use SanDisk Extreme III 8GB and it works without limitations (unless the sensor overheats).
Regards Huw
flickr
bigkuri
Posted 16/11/2009 - 18:47 Link
Thanks - that is EXACTLY what I am going to use. Used to have a few 2GB extreme's, not even sure why I stopped using them as they were faultless.
Thanks guys,
Rick
Mike-P
Posted 16/11/2009 - 19:07 Link
DOes that happen often?
Greytop
Posted 16/11/2009 - 19:22 Link
No not at all, I've only had it happen once when I was doing a marathon test to see if mine had the 'greenline' issue. This was also when we were had quite hot weather.
Just to add I also used it for the odd clip in Provence this August and that was seriously hot but no over heating.
Regards Huw
flickr
