K7, F-- error question
ahamster
Posted 13/02/2011 - 07:36 Link
i am sure i am not the first....have a K-7 and a vivitar non automatic lens that worked flawlessly on my old pentaxs.....can't get this one to take a picture in any mode.....is there a setting?.....or adapter that will help me get this to work? thank you
SmutjeUK
Posted 13/02/2011 - 08:12 Link
I do not have the K-7 but the K-5 but I am sure that the basic is the same.
In your custom settings you have to look for something that calls 'Using Adapter Ring'. You will find that this is set to 'prohibited' which is the default. Just change it to 'Permitted' and you will be fine with the lens.
Kind regards
SmutjeUK
It's nice to be nice!
SmutjeUK
Posted 13/02/2011 - 08:14 Link
I forgot: Welcome to the forum!
Kind regards
SmutjeUK
Posted 13/02/2011 - 09:51 Link
Just to add to that reply, you will need to use stop down metering in manual mode so that the lens stops down correctly. Someone who does this routinely will be along I'm sure to add detail to that process.
ahamster
Posted 13/02/2011 - 09:54 Link
Big thank you to both responses....i will check for a custom setting
fatspider
Posted 13/02/2011 - 10:00 Link
In addition to the above;
You have to set the desired aperture on the lens then press the "Green Button" to take a meter reading and effectively set the correct exposure. you may then press the shutter, dont forget to focus
My PPG link
My Flckr link
Edited by fatspider: 13/02/2011 - 10:01
terje-l
Posted 13/02/2011 - 10:26 Link
The Customs settings item you are looking for is called Using Aperture Ring. This can be set to Permitted or Prohibited. Leave on Permitted. You don't have to change this setting when using automatic lenses.
Terry
dougf8
Posted 13/02/2011 - 11:48 Link
And put the camera in M.
Lurking is shirking.!
