K7 & Sekonic Light meter - EV Increment?
Posted 25/03/2012 - 17:01 - Helpful Comment
It is to set the increment between your EV levels to those set on the camera (which are also adjustable).
On the K-5 the EV Steps menu option allows you to select either 1/2 or 1/3 steps in the EV value (I presume the K-7 has a similar option). You should set your meter steps to the same as the camera:
1/3 set 0.3
1/2 set 0.5
Basically it changes the number of steps between each stop of aperture/shutter speed. i.e. instead of 1/125th, 1/250th, 1/500th by setting half stops (1/2 or 0.5) you get 1/125th, 1/180th, 1/250th, 1/330th, 1/500th...
1/3 set 0.3
1/2 set 0.5
Posted 25/03/2012 - 17:17
I think I've got it - my camera is set to 1/3 steps and it does have the same as yours in options 1/2 or 1/3
so does that mean 0.3 (1/3) gives more range of aperture/shutter speeds when metering? so would this preferable?
Thanks for your help!
Bodies: (digital) K7, Analogue: P30n
Lenses: DA 35mm f2.4, DA 18-.55mm zoom, 28-80mm,
Flash: Metz 58 AF-1
(shh... but I also have a Canon 500D but I only use this for stop motion!)
Flash: Metz 58 AF-1
Posted 25/03/2012 - 17:53 - Helpful Comment
It gives more resolution really (finer control) of the settings, however in auto exposure modes time the shutter is open for is effectively stepless (the camera determines a more precise time and displays the closest speed).
In manual it allows you tune the exposure more finely, handheld meters generally meter to 1/10th stop.
I set mine to 1/2 stops, when 'scrolling through' shutter speeds it takes fewer clicks.
London
I have a Pentax K7 and a Sekonic L-308S and when you press the power and mode button you can set it to match the camera. (?)
0.5, 0.3, 1.0 and a C5 shows at the top of the screen.
is this a number that is permanent or changes depending on camera settings or to do with the F stops ?
here's a youtube video and at 2:40 of the video he shows how to change it but I need to know why and erm... understand! lol
http://www.youtube.com/watch?v=5dKNAzkeiWA
Thanks for any help you can offer.
Flash: Metz 58 AF-1
