K5II and grip - camera 'on' but locks up
Posted 18/02/2013 - 12:11
Which version of firmware is on your K5II?
Posted 18/02/2013 - 14:05
Latest.Which version of firmware is on your K5II?
I've spotted another K5II user over on the US forum asking about the same thing, again involving a grip but not the same lens as me.
Posted 18/02/2013 - 18:05
Hi I have just attached my battery grip to my K5lls and tested the following lens and experienced no problems:
DA* 50 - 135. DA* 16 - 50. DA* 200
Fletcher8.
Posted 18/02/2013 - 18:42
Thanks for that. The problem came after two or three exposures, and (I think) only with my 100mm macro. Did repeat itself, two or three times, but then got better.Hi I have just attached my battery grip to my K5lls and tested the following lens and experienced no problems:
Main issue is the K5II is new, and the grip is new to me.
I don't like intermittent faults
Suppose it could always be an escaped Canikon gremlin. I understand there's plenty of them about:evil
Posted 18/02/2013 - 19:33
Sometimes, when the power is "on" on the grip, and you happen to touch one of the e-dials, they can move in between two positions and cause problems like the one you describe.
Posted 18/02/2013 - 19:34
That was a problem on the K10D/K20D, not heard of it happening on the K-7/K-5 grip.
Posted 18/02/2013 - 22:29
Mike-P wrote:
Are both batteries original Pentax or one is a copy?
Reason I ask is I had it happen a couple of times with my original K-5 but as soon as I started using all oem batteries the locking up stopped.
One original, the other a 'Hama' from SRS. Are both batteries original Pentax or one is a copy?
Do you think they both need to be OEM, or just identical, ie 2x Hama?
Posted 18/02/2013 - 22:30
I did check the e-dials and am sure they were ok, but...
Posted 19/02/2013 - 02:19
It occasionally happens on my K7, not very often, but it does...
Posted 19/02/2013 - 19:44
Happened on my IIs when I 1st got it, 3 times. I said if it did it again I'd send it back but it never did.
Posted 04/03/2013 - 22:22
Anyone had their K5II lock up when the grip is attached?
My K5II locked up twice yesterday ( 3rd March ), grip was attached but not turned on, I only have a battery in the grip and not in the body too.Anyone had their K5II lock up when the grip is attached?
Battery is genuine Pentax.
Removing the battery cured the problem both times.
Posted 05/03/2013 - 10:48
Everything was 'on', including the AF point LED, but the only way I could sort the problem was to remove the battery from the body.
I had a lock up with mine when taking my 3rd photo from receiving the camera this weekend. Took battery out of body to reset and then no problems for the rest of the day.Anyone had their K5II lock up when the grip is attached?
Bob
K5 II, K10D, 18-55mm MkII, SMC-F 70-210, ADII 60-300mm, ADII 80-210mm, ADII 90mm, ADII 300mm, M 28mm F2.8, M 50mm F1.7, Sigma AF 400mm F5.6, Tokina SD 70-210, 16-45mm SA, Sigma 150-500
South London
