K5 will not fire!
Posted 06/12/2010 - 09:29
Use manual settings or set the approriate menu item to "release priority" instead of "focus priority".
Posted 06/12/2010 - 09:30
also make sure your not to close to focus.
Posted 06/12/2010 - 09:48
Where in the setting do I find this? Thats the settings I am looking for but I am going through the 'Bible' but can not find it!Use manual settings or set the approriate menu item to "release priority" instead of "focus priority".
Focus is fine (2m) its just that the time is so long due to the high aperture.also make sure your not to close to focus.
fatspider wrote:
Try focusing on the edge of the paper before cafrefully re-composing the shot. you will obviously have to keep the focus locked by holding the shutter release half pressed.
Tried this one as well but it still refuses to fire. I guess John's tip is the best one (I was looking for this setting anyway plus the setting where it allows me to use my M42 lenses with the manual adaptor) but the book is this big I can not find it in a quick way, hence the question where it is sitting in the menu.Try focusing on the edge of the paper before cafrefully re-composing the shot. you will obviously have to keep the focus locked by holding the shutter release half pressed.
Many thanks for all your help so far
Kind regards
SmutjeUK
It's nice to be nice!
SmutjeUK
Posted 06/12/2010 - 09:49
If your doing the test to see if there are marks on the sensor
it would probably be better out of focus.... i.e. focus set at
infinity.... you don't want to pick up any marks on the paper.
I've not got a K-5 but I presume you have to set it to MF.
Posted 06/12/2010 - 09:54
Errm, No I did not. Good idea (stupid me) but it should not pick anything up from the paper as the shake would show this. All the faults where pretty clear so with the shake of the hand shot it should not matter, but it will not hurt to see if that would overcome the fire blocking.If your doing the test to see if there are marks on the sensor
Thanks for that, never even crossed my mind.
Kind regards
SmutjeUK
SmutjeUK
Posted 06/12/2010 - 09:58
OK got it now the look if I have some of the same.
Kind regards
SmutjeUK
SmutjeUK
Posted 06/12/2010 - 10:38
Unfortunately I no longer have the K-5 so until I buy one I can't help. It is in there somewhere!
Posted 06/12/2010 - 10:42
johnriley wrote:
No worries, thanks anyway as I would be looking for this sooner then later and maybe someone can help me out here in a quick way or I just have to wait toll I find this particular setting in the 'Bible'.Quote:
Unfortunately I no longer have the K-5 so until I buy one I can't help. It is in there somewhere!johnriley wrote:
Many thanks for pointing me towards this anyway John
Kind regards
SmutjeUK
SmutjeUK
Posted 06/12/2010 - 10:55
Turn off 'Catch-in focus'. Page 4, item 25, Custom settings.
Posted 06/12/2010 - 11:04
cardiff_gareth wrote:
Have you done it yet? Manual focus, manual exposure, manual ISO - sorted!
Picture loaded up but still searching for the release priority setting in the menu Have you done it yet? Manual focus, manual exposure, manual ISO - sorted!
Thanks for that. Found the "Aperture Ring" setting as well (#27)
Kind regards
SmutjeUK
SmutjeUK
Posted 06/12/2010 - 16:25
Release priority- Custom setting-page 3- item 15. Af.S setting- 1.Focus priority 2. Release priority.
Posted 06/12/2010 - 16:31
Thanks for that
Kind regards
SmutjeUK
SmutjeUK
Posted 06/12/2010 - 21:48
I wish my K20 and K10 had this setting. anyway I shall be getting a k-5 before too long
Dorset/UK
I know this is a settings issue but could someone just walk me trough it where in the settings I can tell the camera to fire even if the picture may not be sharp or the exposure may be wrong or too long.
I try to see if my sensor has the problems and try to shoot a white paper with a pre-set f22 on AV. I get an exposure of 3seconds with ISO 800 but the camera refuses to fire.
Any chance someone can tell me where I set the settings for ignoring the warnings?
Many thanks.
SmutjeUK
