K5 sharpness settings
Posted 31/05/2012 - 20:24
How do you get the pictures to expand in this site instead of them opening up a new tab.
Pentax K5, Kx, DA15 ltd,18-135, 18-55, 50-200, M100 f4 macro, M135 f3.5 A28 F2.5
Posted 31/05/2012 - 21:44
You can't, the forum software has limitations.
If you want to explore sharpening, which is a huge subject, then I can recommend Martin Evening's books on Photoshop. There are lots of different approaches depending on subject and image size.
You are a PU Plus member, so you also have access to my two short articles on sharpening.
Posted 31/05/2012 - 21:54
How do I get them John.
John
John
Posted 31/05/2012 - 22:10
https://www.pentaxuser.com/article/photoshop-sharpening-technique-262
https://www.pentaxuser.com/article/sharpening-method-in-photoshop-263
Sharpening is best done in Photoshop (or a similar program) but a small amount in the camera is OK, I would suggest +1.
Posted 31/05/2012 - 23:10
Out-of-camera sharpening techniques aside, this is a fairly poor subject image with which to compare the sharpness levels.
It basically has one and only one in-focus contrast transition that sharpening would do anything much with.
Hopeless, really. You really need something with a lot more detail, where any differences are a lot more obvious.
Posted 01/06/2012 - 00:03
johnboy-22 wrote:
I wanted to see if I could find any difference in the sharpness settings.
Did you find any difference?I wanted to see if I could find any difference in the sharpness settings.
I can't see any, and if you shot these RAW there won't be any difference because the RAW image is unaffected by some settings, including sharpness.
Posted 01/06/2012 - 07:14
John
Turnberry,
Ayrshire
Normal sharpness
5 to right
f sharp5 to right
ex sharp 5 to right
