K5 SD Card stuck.
Posted 30/12/2012 - 14:30 Link
Has anybody had the SD card stick in a K5,mine has never come out far, but now it dosnt come out at all, bit annoying as the camera was only got last March.
Dave.
Auto110,MZ-30, K5, loads of Black Tubes with Glass in.
Edited by HappySnapper65: 30/12/2012 - 14:30
AndrewA
Posted 30/12/2012 - 14:31 Link
Nope, mine always felt fiddly to get out, but I have now developed a method that basically fires it out!
Hope you get it sorted.
PPG link
Flickr link
JohnX
Posted 30/12/2012 - 14:50 Link
Method seems to be to push the card in with a thumb nail, then keeping the pressure on the end of the card slid the nail off, at which point the card will spring out.
SteveEveritt
Posted 30/12/2012 - 20:00 Link
I had a similar problem with a Canon bridge in work. Someone had inserted the card wrongly and a piece of the plastic near the contacts had broken and was jamming the card in. There was only one solution..... Rip it out! I then took the camera apart to remove the piece of plastic, amazingly when I put it all back together it worked perfectly.
The camera was beyond warranty and I wouldn't advise this as a solution.
Posted 02/01/2013 - 14:11 Link
Found the problem, the memory card had split at the seam, pulled it out with a pair of tweezers, new memory card is OK.
Now got to try and fight the card warranty.
Dave.
Mannesty
Posted 02/01/2013 - 14:50 Link
Life's too short, chuck it and move on .
