K5 and Vivitar 3500
Posted 19/12/2010 - 16:26
I was looking at that page earlier John and 6 - 9V should be ok but I thought I'd ask in the hope that someone else may have risked a current Pentax with the 3500!
Vic.
Vic.
K5, LightRoom 5
Posted 19/12/2010 - 16:31
Be careful because Vivitar sourced their guns from various manufacturers and the same model number can have a very different trigger voltage. The safe way is to measure it with a voltmeter. Or simply use a modern flashgun!
Posted 19/12/2010 - 16:49
Thanks for that John, I'll check the voltage!Be careful because Vivitar sourced their guns from various manufacturers and the same model number can have a very different trigger voltage. The safe way is to measure it with a voltmeter. Or simply use a modern flashgun!
Vic.
K5, LightRoom 5
Posted 22/12/2010 - 08:08
You could use a radio trigger, which will not require the gun to be mounted on the camera.
From memory, the 3500 had a nice macro metering kit.
Surrey
Vic.
