K5 "dead"?
Posted 01/05/2012 - 17:13
Have you tried taking the card out and re reinserting it?
You could also try to format the card in the camera.
Barrie - Too Old To Die Young
Posted 01/05/2012 - 17:19
Do you get the preview screen with the shutter/aperture, etc data displayed? It may be something as simple as you accidentally nudging a button, to a loose/broken wire connecting the screen to the mainboard. It might clear itself if you remove the battery for a couple of mins, then re-insert it.
Posted 01/05/2012 - 17:24
Also try recharging the battery in case it has coincidentally just run out.
John
John
Posted 01/05/2012 - 17:35
Thanks for the ideas - I don't have a preview screen info - it is blank. I am trying the "remove battery" routine at the moment ( it is fully charged ).
Posted 01/05/2012 - 17:37
Success! Battery removal and re-insertion has fixed it - bizarre!!! Thanks all.
Posted 01/05/2012 - 17:58
Very good!
Posted 01/05/2012 - 19:08
Looks like a case of heavy static getting on the card and passing to the camera?
Posted 01/05/2012 - 19:11
Static would have wiped the card out totally. Static electricity and electronics are not a good combination, I'm afraid!
